Home » Eclipse Projects » Rich Client Platform (RCP) » Specify multiple paths for JVM in ini file?
Specify multiple paths for JVM in ini file? [message #536396] Thu, 27 May 2010 21:11 Go to next message
Ken is currently offline Ken
Member
In my product ini file I can set the vm for it to use; something like:
-vm
.../jre/bin
-vmargs
-Xms256m
-Xmx512m
Works fine. This looks for the jre one folder up. Is there a way to have it
search multiple paths? I tried:
(newline)
-vm
.../jre/bin
../jre/bin
(comma)
-vm
.../jre/bin, ./jre/bin
(semi-colon)
-vm
.../jre/bin; ./jre/bin
(space)
-vm
.../jre/bin ./jre/bin
(two vm flags - just uses the last)
-vm
.../jre/bin
-vm
../jre/bin
Anyone else have any ideas?
- Ken
Re: Specify multiple paths for JVM in ini file? [message #536542 is a reply to message #536396] Fri, 28 May 2010 11:43 Go to previous message
Andrew Niefer is currently offline Andrew Niefer
Sorry, the launcher does not support anything like this.
The best I could think of would be to write a script that does the searching
and then executes the vm.
Or, modify the system path environment variable before launching and don't
specify -vm. (Though eclipse/jre will be checked before the system path).
-Andrew
> -vm
> ../jre/bin
> -vmargs
> -Xms256m
> -Xmx512m
> it search multiple paths? I tried:
> (newline)
> -vm
> ../jre/bin
> ./jre/bin
> (comma)
> -vm
> (semi-colon)
> -vm
> (space)
> -vm
> -vm
> ../jre/bin
> -vm
> ./jre/bin
> - Ken
Previous Topic:non-scrolling form anywhere?
Next Topic:RCP application configuration files
Current Time: Sat May 25 23:23:42 EDT 2013
Powered by FUDForum. Page generated in 0.01488 seconds
