Home » Eclipse Projects » Rich Client Platform (RCP) » How to dispose a view programmatically?(When my cloned perspective gets deleted, I want its views to be disposed.)
How to dispose a view programmatically? [message #536133] Thu, 27 May 2010 04:30 Go to next message
Marton Sigmond is currently offline Marton Sigmond
Member
I use views associated with a particular perspective (i.e. allowMultiple=true; secondaryId=perspectiveId).
I clone a perspective when I need it, and delete it when I do not need it anymore.
However, the views associated with the deleted perspective do not get disposed.
How could I achieve, that those views get disposed (programmatically, declaratively, etc.)?
Thank you for your help.
Marton
Best Regards,
Marton Sigmond
Software Design Engineer
Re: How to dispose a view programmatically? [message #536281 is a reply to message #536133] Thu, 27 May 2010 10:35 Go to previous messageGo to next message
Member
I guess this is what I was looking for:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().closePerspective(perspDesc, true, false);
Could anyone please confirm that this is a legal way to dispose a perspective and all associated views?
Also since I found the above solution, I do not invoke the IPerspectiveRegistry.deletePerspective() method anymore.
Is this correct so?
Marton
Best Regards,
Marton Sigmond
Re: How to dispose a view programmatically? [message #536296 is a reply to message #536281] Thu, 27 May 2010 10:52 Go to previous message
Paul Webster is currently offline Paul Webster
> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().closePerspective(perspDesc,
> true, false);
This is API (good), and will close the perspective and hide all of its
views.
Delete perspective should delete the perspective descriptor from the
registry.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Feature Export in 3.5 not creating feature jnlp file
Next Topic:How to get the application id?
Current Time: Fri May 24 12:46:15 EDT 2013
Powered by FUDForum. Page generated in 0.04534 seconds
