Home » Modeling » AMW » XML to Ecore Tranformation needed!
XML to Ecore Tranformation needed! [message #534879] Thu, 20 May 2010 10:34 Go to next message
Alexey is currently offline Alexey
Member
Hi!
I hope, it's ok, that i post so many new topics here Smile
Now, I have all a need to start an ATL - Transformation (AMW - Level is done: - ATL-file generated).
BUT! Unfortunatelly is my input model - an xml-file.
And as far as I understand, it must be km3 or ecore (or xmi?), in order to include it in an ATL-transformation.
Please, could someone advise me, how to transform an xml to ecore or KM3 (or xmi)?
Thanks a lot!
Alexey
[Updated on: Thu, 20 May 2010 10:49]
Report message to a moderator
Re: XML to Ecore Tranformation needed! [message #534905 is a reply to message #534879] Thu, 20 May 2010 11:36 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARD
You can use EMF directly (see here) or use the AM3 XML injector which will inject the xml file to a standard XML model (using the concepts of Nodes, Attributes, Texts, Root).
Re: XML to Ecore Tranformation needed! [message #536178 is a reply to message #534905] Thu, 27 May 2010 06:27 Go to previous message
Member
Sylvain EVEILLARD wrote on Thu, 20 May 2010 11:36
Thank you! I will try the injector!
Previous Topic:QATL: "Model - extract to ATL" - option not found!
Next Topic:Eclipse 3.4.2 reads XMI 2.1 with errors!
Current Time: Sat May 25 16:02:46 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
