Home » Language IDEs » C / C++ IDE (CDT) » What happened to "GDB Hardware Debugging" in the debug configurations?
What happened to "GDB Hardware Debugging" in the debug configurations? [message #536034] Wed, 26 May 2010 17:34 Go to next message
John McCabe is currently offline John McCabeFriend
Sorry if I'm catching up a bit, but some time ago I mentioned that I'd
got issues with GDB Hardware Debugging in Eclipse (Europa I think).
I've now got Galileo with CDT 6.02 but there's no GDB Hardware
Debugging configuration group in there.
Is it supposed to be not there? One of the reasons I ask is that I
found a thread about it here:
http://dev.eclipse.org/mhonarc/lists/cdt-dev/msg18685.html
Sounds intriguing.
John
Re: What happened to "GDB Hardware Debugging" in the debug configurations? [message #536117 is a reply to message #536034] Thu, 27 May 2010 07:12 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
Did you install the plugin for hardware debugging? I think it is not in the default installation.
Help->Install New Software
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: What happened to "GDB Hardware Debugging" in the debug configurations? [message #536194 is a reply to message #536117] Thu, 27 May 2010 10:39 Go to previous messageGo to next message
On Thu, 27 May 2010 03:12:07 -0400, Axel Mueller <aegges@web.de>
No - I hadn't as it wasn't listed on the main Galileo update site and
the link I found to the CDT update site didn't have it.
However I have now found the
http://download.eclipse.org/tools/cdt/releases/galileo update site
thanks to your help so I have installed it now.
Thank you.
Re: What happened to "GDB Hardware Debugging" in the debug configurations? [message #536316 is a reply to message #536194] Thu, 27 May 2010 15:31 Go to previous message
On Thu, 27 May 2010 11:39:08 +0100, John McCabe
It would appear that the update site I found was out of date. When you
do a search on Eclipse CDT Update Site on google it comes up with:
http://download.eclipse.org/tools/cdt/releases/new/
as the first item which is a bit disappointing as that looks way out
of date. To be honest one of the things I find disappointing in
general with Eclipse links is that they seem to quite often abandon
pages and create new ones elsewhere rather than moving and updating
the old ones! At the end of the day though, I could have put more
effort in to looking around for other links.
... and have managed to debug using it!
Previous Topic:Embedded Debugging with Eclipse and Abatron BDI2000
Next Topic:Help with setup
Current Time: Sat Jul 22 09:07:28 GMT 2017
Powered by FUDForum. Page generated in 0.02626 seconds
