Home » Modeling » M2T (model-to-text transformation) » [Check] metatype function
[Check] metatype function [message #535621] Mon, 24 May 2010 19:01 Go to next message
Elhamlaoui Mahmoud is currently offline Elhamlaoui Mahmoud
Hi, what is the use of a metatype( ) function under check and what does does it take in its parameter.
thanks mahmoud
Re: [Check] metatype function [message #535670 is a reply to message #535621] Tue, 25 May 2010 04:31 Go to previous message
Christian Dietrich is currently offline Christian Dietrich
don't know what you exactly mean with metatype function and parameters but you can call .metaType on any Object in Xtend to get the corresponding (internal) metaclass
~Christian
Previous Topic:[Acceleo] Running a installed acceleo bundle from a Java main method
Next Topic:[xpand]How to generate C++ code?
Current Time: Mon Jun 17 23:41:47 EDT 2013
Powered by FUDForum. Page generated in 0.02934 seconds
