| TreeRidget Custom Icon [message #534167] |
Tue, 18 May 2010 05:00  |
Originally posted by: matthias.rodler.gmx.net
I'm currently using Riena 1.2.0.0 and want to use custom items with my
TreeRidget but I'm only able to use resources which are within the riena
client plugin(the keys are defined in
org.eclipse.riena.internal.ui.ridgets.swt.SharedImages).
Is there any possibility to use own resources or have I missed something?
Thanks.
Matthias
| Re: TreeRidget Custom Icon [message #535636 is a reply to message #535026] |
Tue, 25 May 2010 00:47  |
Thank you Elias I will try this way.
Matthias
Am 21.05.2010 08:42, schrieb Elias Volanakis:
> Hi Matthias,
> I believe your use case should work. See SnippetTreeRidget005 for a
> starting point.
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.riena/o rg.eclipse.riena.sample.snippets/src/org/eclipse/riena/sampl e/snippets/SnippetTreeRidget005.java?root=RT_Project&vie w=co
> If the image is not in SharedImages the ImageStore is asked:
> Activator.getSharedImage(...) {
> image = ImageStore.getInstance().getImage(imageKey);
> I'm not an expert on ImageStore (maybe another developer can confirm
> this), but I believe you have to add the directory that has your the
> images to the plugin.xml:
> <extension
> point="org.eclipse.riena.ui.swt.imagePaths">
> <path
> path="icons">
> </path>
> </extension>
> Then you can use the imageName as a String value (file extension
> optional). This won't work in the Snippet, since there is no plugin.xml
> / ExtensionPoints in the snippets.
> If you run into problems, please attach a runnable example to bugzilla
> and I'll work this out with you.
> Elias.
| Re: TreeRidget Custom Icon [message #585619 is a reply to message #534167] |
Thu, 20 May 2010 09:03  |
Thorsten Schenkel Messages: 14 Registered: July 2009 |
Junior Member |
Am 18.05.2010 11:00, schrieb Matthias Rodler:
Hallo,
in Riena it is not possible to change the images of folders of the tree.
The Riena Look&Feel provides a set of keys to define these images:
SUB_MODULE_TREE_FOLDER_OPEN_ICON
SUB_MODULE_TREE_FOLDER_CLOSED_ICON
SUB_MODULE_TREE_DOCUMENT_LEAF_ICON
But these are not displayed in the tree. See Bug #273817 -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273817
greeting
Thorsten
> Thanks.
> Matthias
| Re: TreeRidget Custom Icon [message #585688 is a reply to message #585631] |
Matthias
> Hi Matthias,
> starting point.
> <extension
> <path
> path="icons">
> </path>
> </extension>
> Elias.
FUDForum. Page generated in 0.02293 seconds
