Home » Eclipse Projects » DTP » Reverse engineer DBSchema to XSD
Reverse engineer DBSchema to XSD [message #53426] Wed, 11 March 2009 13:45 Go to next message
Ravikanth Somayaji is currently offline Ravikanth Somayaji
Member
Hi All,
I have an assignment of extracting the DB schema into a Domain Specific
Language.
However, I'd be very pleased if there was a tool that converted DB Schema
to XSD.
Thanks, Ravi
Re: Reverse engineer DBSchema to XSD [message #53535 is a reply to message #53426] Fri, 13 March 2009 10:43 Go to previous message
Eclipse User
Originally posted by: brianf.sybase.com
Hi Ravi!
Since we use an EMF model under the covers to model the actual contents of
the database from a JDBC perspective, I wonder if there's a way to convert
the actual model objects into XSD?
--Fitz
"Ravikanth " <ravikanth.somayaji@gmail.com> wrote in message
news:41a6ea1e874abcdf6caecf288566a729$1@www.eclipse.org...
> Hi All,
> Language.
> to XSD.
> Thanks, Ravi
Re: Reverse engineer DBSchema to XSD [message #594672 is a reply to message #53426] Fri, 13 March 2009 10:43 Go to previous message
Brian Fitzpatrick is currently offline Brian Fitzpatrick
Hi Ravi!
--Fitz
> Hi All,
> Language.
> to XSD.
> Thanks, Ravi
Previous Topic:How do I create a Connection Profile
Next Topic:Error: Method can be called only once.
Current Time: Tue May 21 06:14:50 EDT 2013
Powered by FUDForum. Page generated in 0.01676 seconds
