Home » Eclipse Projects » Orbit » SLF4j Version 1.6.0
SLF4j Version 1.6.0 [message #535206] Fri, 21 May 2010 10:55 Go to next message
Stephan Leicht Vogt is currently offline Stephan Leicht Vogt
Member
When will the new version of SLF4j be available on orbit? If it helps I could contribute it (although I'm no contributer to orbit).
Thanks and greetings
Stephan Leicht
Re: SLF4j Version 1.6.0 [message #535369 is a reply to message #535206] Sat, 22 May 2010 16:35 Go to previous messageGo to next message
David Williams is currently offline David Williams
Stephan Leicht wrote:
> Hi
> Stephan Leicht
Probably not until (at least) July, as we are stabizing now for June
release. You could as on orbit-dev list, and probably get a more direct
answer from those who contributed version 1.5.11 and others.
Re: SLF4j Version 1.6.0 [message #548203 is a reply to message #535206] Wed, 21 July 2010 01:49 Go to previous message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
Hi Stephan,
Am 21.05.2010 16:55, schrieb Stephan Leicht:
As soon as there is a CQ we can add it. Did you open one already?
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Previous Topic:javax.xml buddy policy
Next Topic:GWT-User not installable with p2
Current Time: Thu May 23 03:17:46 EDT 2013
Powered by FUDForum. Page generated in 0.01675 seconds
