Home » Modeling » OCL » Add Pacakge imports to the OclParser
Add Pacakge imports to the OclParser [message #534917] Thu, 20 May 2010 11:34 Go to next message
Eclipse User
Originally posted by: philipp.berger.student.hpi.uni-potsdam.de
Hey guys,
I just tried to parse an OCL expression like
....self.oclAsType(MyType1)..., so I got a type not found exception,
which I could fix by giving the full qualified name of the class
....self.oclAsType(org::packageTwo::MyType1)...
This constraint is defined for an EClass in PackageOne, this package has
no references to PackageTwo, but I like to handle subclasses from
PackageTwo in the constraint.
This problem occured while using the org.eclipse.emf.importer.rose for
porting models. In the Rose context all expressions are defined without
full qualified names, but after importing the class visibility seems to
be changed.
So my question, is it possible to bind severall packages to the
OclParser to avoid full qualified names?
Re: Add Pacakge imports to the OclParser [message #534950 is a reply to message #534917] Thu, 20 May 2010 14:38 Go to previous message
Hi Philipp
You don't make clear whether you are using a CompleteOCL document or a
casual EssentialOCL query.
For an EssentialOCL query it is your responsibility/capability to
configure the package registry, so it may be possible with some
imagination, but probably requires a lookup algorithm change.
For CompleteOCL, http://www.omg.org/issues/issue14599.txt suggests the
addition of an import declaration, although I had envisaged that
import 'uri'
would load a meta-model, requiring full package qualification.
The OCL specification makes extensive (almost exclusive) use of
unqualified names so perhaps:
import 'uri#/Package1'
should make Package1::Type1 avaialable as just Type1 and
import myuri : 'uri#/Package1'
should make Package1::Type1 available as just myuri::Type1.
The new Xtext editor supports the latter.
Ed Willink
On 20/05/2010 16:34, Philipp Berger wrote:
> Hey guys,
> be changed.
Previous Topic:OCL constraint: blank character in a string
Next Topic:EConstraint in Ecore Model
Current Time: Sat May 25 11:41:25 EDT 2013
Powered by FUDForum. Page generated in 0.01429 seconds
