Home » Eclipse Projects » Rich Client Platform (RCP) » reuse Java perspective in an RCP application
reuse Java perspective in an RCP application [message #530767] Fri, 30 April 2010 14:31 Go to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
I'd like to give to my RCP application the Java perspective, how can I
reuse that?
I found JavaPerspectiveFactory but it's in an internal package...
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: reuse Java perspective in an RCP application [message #531020 is a reply to message #530767] Mon, 03 May 2010 08:11 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
You need to include all of JDT and Platform in your RCP app. Then you
set the default perspective in your plugin_customization.ini file:
org.eclipse.ui/defaultPerspectiveId=org.eclipse.jdt.ui.JavaP erspective
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: reuse Java perspective in an RCP application [message #534170 is a reply to message #531020] Tue, 18 May 2010 05:27 Go to previous messageGo to next message
this however does not show the standard File menu, edit menu, etc...
thanks in advance
cheers
Lorenzo
Re: reuse Java perspective in an RCP application [message #534245 is a reply to message #534170] Tue, 18 May 2010 08:56 Go to previous messageGo to next message
That's all created by the action bar advisor for your app, in the IDE
case that's org.eclipse.ui.internal.ide.WorkbenchActionBuilder
PW
Paul Webster
Re: reuse Java perspective in an RCP application [message #534317 is a reply to message #534245] Tue, 18 May 2010 11:53 Go to previous messageGo to next message
> PW
Thanks Paul
so back to my original post: there's no easy way to recreate what I see
when I run eclipe with the Java perspective in my RCP application, but
to copy some code from an internal class, right?
cheers
Lorenzo
Re: reuse Java perspective in an RCP application [message #534530 is a reply to message #534317] Wed, 19 May 2010 08:45 Go to previous messageGo to next message
You have to basically provide everything in your RCP app that would
support the Java perspective. That means most of the setup for the IDE
workbench as well.
It's either that, or run the org.eclipse.ui.ide.workbench application.
Basically, run JDT and add your plugins to that, instead of trying to
add parts of JDT to your RCP app.
PW
Paul Webster
Re: reuse Java perspective in an RCP application [message #534550 is a reply to message #534530] Wed, 19 May 2010 09:56 Go to previous messageGo to next message
>> see when I run eclipe with the Java perspective in my RCP application,
>> but to copy some code from an internal class, right?
> workbench as well.
> PW
OK, so if I understand correcly, I must create a product configuration
which refers to my product, and uses org.eclipse.ui.ide.workbench as the
application, in fact in my plugin.xml I now have:
<extension
id="product1"
point="org.eclipse.core.runtime.products">
<product
application="org.eclipse.ui.ide.workbench"
name="SWRTJ IDE">
</product>
</extension>
I added the required plugins in the product configuration, and I can run
this product from eclipse. However, if I export it with the product
wizard, the plugins and configuration directories are created but no
executable is created...
I've been struggling with these issues (try to create a product that
runs as the application the ide workbench instead of my own application)
for days and I can't seem to solve it...
thanks in advance
Lorenzo
Re: reuse Java perspective in an RCP application [message #534552 is a reply to message #534550] Wed, 19 May 2010 10:14 Go to previous message
For actually creating this kind of product, probably feature based is
useful.
org.eclipse.rcp and org.eclipse.platform are the basis for the IDE
application itself. Then include the JDT feature to get JDT on top of that.
For e4 we created a feature based product. For the runtime to work you
would need:
org.eclipse.platform (which includes org.eclipse.rcp), org.eclipse.jdt
(possibly org.eclipse.help and org.eclipse.cvs). Then we included our
feature, org.eclipse.e4.sdk.runtime.feature.
Then to generate a product (we used an Eclipse SDK p2 repository) we
also needed the org.eclipse.rcp.configuration feature. It shows up as
an error, but it is needed during the build in order to generate the
launcher (it has the binary artifacts).
See
http://dev.eclipse.org/viewcvs/index.cgi/e4/org.eclipse.e4.u i/examples/org.eclipse.e4.ui.examples.legacy.workbench/legac y-eclipse.product?view=co
for our example .product file. We have more in there because we include
all of the source plugins in our build as well (necessary to see
workbench source and get extension point help in plugin.xml editors, but
that's only if you use PDE).
PW
Paul Webster
Previous Topic:Set Focus on PropertyDescriptor Cell
Next Topic:IViewSite (ico multi-instance view): no means to update secondaryId
Current Time: Mon May 20 09:26:39 EDT 2013
Powered by FUDForum. Page generated in 0.01837 seconds
