Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » NumberFormatException when running some tests with the http recorder
NumberFormatException when running some tests with the http recorder [message #53450] Fri, 10 February 2006 09:54
Eclipse User
Originally posted by: angela.constantinesc.zetvisions.com
Hi!
i am running some tests with the http recorder, and i got twice this error:
System.out:
java.lang.NumberFormatException: For input string: "eHeight"
and once a "java.lang.Exception: rc=-1"
the "eHeight" comes from this line in the html source:
HM_GL_ImageHeight = 9;
This happens when I run the tests locally, i.e. on the local copy of a
portal. However, i once also got it when running a test on the eclipse
website. These two tests were done on different computers.
Can anyone help, please??
Previous Topic:Problem when AGR is playbacking
Next Topic:I just want TPTP to work once.
Current Time: Tue May 21 07:02:47 EDT 2013
Powered by FUDForum. Page generated in 0.05676 seconds
