| How to set up a JPA project to use Maven? [message #534374] |
Tue, 18 May 2010 17:34  |
Shelli Orton Messages: 67 Registered: September 2009 |
Member |
I am looking for advice on how to set up an EJB/JPA project in Eclipse that uses Maven. I have Galileo with m2eclipse and WTP installed.
This is my first EJB3 project, so there's lots of learning happening.
I looked for a Maven archetype, but the only ones I could find were for JBoss/Hibernate and I am using Glassfish.
I created a new simple Maven project and then added these facets to it:
EJB Module 2.1
Java 6.0
Java Persistence 1.0
I was then able to use the JPA Tools to autogenerate entity classes from database tables. So I now have a project with this structure:
EJBProject\EJBProject
EJBProject\.classpath
EJBProject\.project
EJBProject\.settings
EJBProject\pom.xml
EJBProject\ejbModule
EJBProject\ejbModule\META-INF\MANIFEST.MF
EJBProject\ejbModule\META-INF\orm.xml
EJBProject\ejbModule\META-INF\persistence.xml
{deleted the ejb-jar.xml file}
EJBProject\src\main\java\my\project\Table1.java
EJBProject\src\main\java\my\project\Table2.java
EJBProject\src\main\java\my\project\Table3.java
EJBProject\src\main\resources
EJBProject\src\test\java
EJBProject\src\test\resources
EJBProject\target\classes
EJBProject\target\test-classes
I'm not sure what to with this project now to manage it with Maven. I came across this blog post:
http://famvdploeg.com/blog/2008/08/building-ejb3-application s-with-maven-2/
which created its project structure from scratch/manually. Would the "ejbModule" directory that Eclipse created be equivalent to the "ejb-jar" directory in the blog? Do I need to create "ear" and "war" directories (and respective pom files)?
Any direction in how to set up my project (directory structure and pom files) is greatly appreciated.
| Re: How to set up a JPA project to use Maven? [message #534574 is a reply to message #534386] |
Wed, 19 May 2010 11:06  |
Member |
I added the Open Archetypes Snapshot remote catalog to my Maven Archetypes, but when I tried to create a project based on the
mulit-javaee5-archetype, I get the message:
Failed to create project.
at org.apache.maven.artifact.repository.DefaultArtifactRepositoryFactory.createArtifactRepository(DefaultArtifactRepositoryFactory.java:90)
at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.resolveArchetype(ProjectConfigurationManager.java:540)
at org.maven.ide.eclipse.internal.project.ProjectConfigurationManager.createArchetypeProject(ProjectConfigurationManager.java:463)
at org.maven.ide.eclipse.wizards.MavenProjectWizard$5.runInWorkspace(MavenProjectWizard.java:279)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
I'm using the 0.10.0.201000209-0800 version of m2eclsipse.
[Updated on: Wed, 19 May 2010 11:14] Report message to a moderator
FUDForum. Page generated in 0.01873 seconds
