| Xpand suppress return value output [message #534171] |
Tue, 18 May 2010 05:39  |
Dennis Messages: 2 Registered: May 2010 |
Junior Member |
Hello everybody,
I'm quite new to this topic, and currently I am trying to create a small sample DSL for my Bachelor Thesis...
I succeeded in creating something like a Homepage-DSL for generating html files, and now I would like to develop another generator which creates .tex files from this Homepage DSL Model.
But I'm stuck with the problem of creating tex tables
The output of the generator should look something like:
\begin{tabular}{|l|l|}
Left upper corner&Right upper corner\\
Left lower corner&Right lower corner\\
This is a table with two columns => So i figured to use this:
«DEFINE column FOR Column»
«EXPAND element FOR elements.first()»
«elements.remove(elements.first())»
&«EXPAND element FOREACH elements»
«ENDDEFINE»
The problem is that elements.remove(elements.first()) will print [ ] to my tex code. How do I suppress this output?
Any idea? Thank you!
[Updated on: Tue, 18 May 2010 05:40] Report message to a moderator
| Re: Xpand suppress return value output [message #534187 is a reply to message #534171] |
Tue, 18 May 2010 06:20   |
MaximeLecourt Messages: 108 Registered: February 2010 Location: France |
I don't really know how to help you, but you can use
elements.withoutFirst() instead of elements.remove(elements.first())
From my experience, [ ] is the sign of a List.
Can you paste what exact text output you get ?
One day I shall master M2T, but that day has yet to come...
FUDForum. Page generated in 0.02523 seconds
