Home » Eclipse Projects » EclipseLink » Implementing aggregate boolean functions in JPQL?
Implementing aggregate boolean functions in JPQL? [message #533496] Fri, 14 May 2010 05:28 Go to next message
Dean Ashby is currently offline Dean Ashby
I'm trying to implement the equivalent of an aggregate boolean AND function. The following query is based on pure SQL ideas taken from this article and although it shows what I'm trying to achieve, it's not valid JPQL:
SELECT
    NEW BookingSummaryDto( b.id, b.bookingReference, SUM(i.price), MIN(CASE WHEN i.paid THEN 1 ELSE 0 END) )
FROM
    Booking AS b JOIN b.items AS i
GROUP BY
    b.id, i.bookingReference
The other methods described in the article don't appear to be possible with JPQL either as they involve sub-queries in the from clause.
Can anyone suggest a way to achieve this in JPQL?
Dean
Re: Implementing aggregate boolean functions in JPQL? [message #533971 is a reply to message #533496] Mon, 17 May 2010 11:14 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
You could try using EclipseLink 2.1/trunk as we have improved our JPQL support. Sub-queries in the from clause are still not supported through (you can add an enhancement request for this).
Otherwise, you could use a native SQL query.
James : Wiki : Book : Blog
Re: Implementing aggregate boolean functions in JPQL? [message #534045 is a reply to message #533971] Mon, 17 May 2010 15:36 Go to previous message
Thanks for your comments James. I did end up going the native SQL way in the end.
Previous Topic:When I set FirstResult and MaxResult how I can get the total ( count() )
Next Topic:No Persistence provider from dependency
Current Time: Thu May 23 09:50:34 EDT 2013
Powered by FUDForum. Page generated in 0.05628 seconds
