| Re: OCL constraint [message #533765 is a reply to message #533329] |
Sun, 16 May 2010 16:43   |
Originally posted by: Alexander.Igdalov.gmail.com
Hi Esin,
I would recommend you to write this operation in Java. Refer to
"Customizing the Environment" section of the OCL Developer Guide (in
Help) for details.
Your statement
> " not (self.name->includes(' ')) "
doesn't check for spaces but converts a String (i.e. self.name) to a Set
of Strings containing one element (self.name) and attempts to find a
String equal to ' '.
HTH,
- Alex.
esin wrote:
> Hi there,
> I have a trouble in an OCL constraint that checks the blank characters
> in a string. I cannot write a constraint using the operations defined on
> OCL String. Following constraint is not working either. Could anyone
> help me?
| Re: OCL constraint [message #533935 is a reply to message #533921] |
Mon, 17 May 2010 10:06   |
Cool! That's what an expert advice is!
Christian W. Damus wrote:
> Hi, all,
> A less pleasant-looking alternative to Java is:
> (1..self.name.size())->collect(i |
> self.name.substring(i, i))->excludes(' ')
> which basically includes an expansion of the OCL 2.2 characters()
> operation.
> Christian
> On 13/05/10 08:14 AM, esin wrote:
>> Hi there,
>> help me?
| Re: OCL constraint [message #533946 is a reply to message #533921] |
Mon, 17 May 2010 10:27  |
Esin Karabacakoglu Messages: 11 Registered: May 2010 Location: Turkey |
Junior Member |
Hi all,
Thanks for your replies. With the helps of all you, i solved my problem. And here is the solution:
Sequence{1..self.name.size()}->collect(i |self.name.substring(i, i))->excludes(' ')
FUDForum. Page generated in 0.08867 seconds
