Home » Modeling » GMF (Graphical Modeling Framework) » GMF Diagram without Resource?
GMF Diagram without Resource? [message #514741] Tue, 16 February 2010 09:13 Go to next message
Giovanni De Sossi is currently offline Giovanni De Sossi
it's possible to create and open a GMF Diagram without a Resource (e.g. a File), but instead with a runtime model? If so, where can I find some code sample?
Giovanni.
Re: GMF Diagram without Resource? [message #514778 is a reply to message #514741] Tue, 16 February 2010 05:54 Go to previous messageGo to next message
Ali Koudri is currently offline Ali Koudri
You have to implement The IStorageEditorInput interface and pass it to
your editor through the setInput() method using cast.
Best regards.
Le 16/02/2010 15:13, giovanni a écrit :
> code sample?
> Giovanni.
Re: GMF Diagram without Resource? [message #514784 is a reply to message #514778] Tue, 16 February 2010 10:58 Go to previous messageGo to next message
Hi Ali,
thank you very much, I'll give it a try
Giovanni.
Re: GMF Diagram without Resource? [message #515363 is a reply to message #514778] Thu, 18 February 2010 10:11 Go to previous messageGo to next message
Hi Ali,
have you any idea how can I implement an IStorageEditorInput (better: an IStorage) which reads an in-memory model object?
Especially, I'm confused about the implementation of public InputStream getContents() method: did you know any example I can read?
Thank you
Giovanni.
Re: GMF Diagram without Resource? [message #515904 is a reply to message #514741] Mon, 22 February 2010 03:00 Go to previous messageGo to next message
Esteban Dugueperoux is currently offline Esteban Dugueperoux
Hi Giovanni,
I would like to do the same thing like you.
I have seen this thread
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03878.html
where someone create at each GMF editor opening a new temporary diagram
file by overriden setInput() method, without better solution.
Indeed it would be nice to display with a GMF editor a domain model in
memory with a diagram model created on the fly in memory. But it doesn't
seems possible to use EMF Transaction without associated Resource and a
GMF editor needs transaction to read or write on models.
But by using CDO with a in-memory database would it be possible to
resolve this problem? Although with CDO we can't yet edit models with GMF?
Someone have any (other) idea?
Re: GMF Diagram without Resource? [message #515911 is a reply to message #515904] Mon, 22 February 2010 03:41 Go to previous messageGo to next message
Hi Esteban,
I think you can found this tutorial useful to suite your needs: http://www.elver.org/hibernate/gmftutorial/tutorial1.html .
It's about using Teneo Hibernate having a database as editor input:
page.openEditor(new URIEditorInput(StoreController.DATABASE_URI),
MindmapDiagramEditor.ID);
Giovanni.
Re: GMF Diagram without Resource? [message #515953 is a reply to message #515363] Mon, 22 February 2010 00:46 Go to previous messageGo to next message
sorry for the late answer, here is a sample of what I did:
1. I have implemented the IStorageEditorInput interface representing the
inputs of my editor, which is actually an object (not a file)
public class MyEditorInput implements
IStorageEditorInput {
private MyObject object;
public MyObject getObject() {
return object;
public void setObject(MyObject object) {
this.object = object;
public MyEditorInput(MyObject object) {
public IStorage getStorage() throws CoreException {
return null;
public boolean exists() {
return false;
public ImageDescriptor getImageDescriptor() {
return null;
public String getName() {
//insure that object have a name property
//or use adapters
return object.getName();
public IPersistableElement getPersistable() {
return null;
public String getToolTipText() {
return "My Object";
public Object getAdapter(Class adapter) {
return null;
2. Add a property to your editor and modify related methods
public class MyEditor extends DiagramDocumentEditor implements
IGotoMarker {
//input
private MyEditorInput editorInput;
public void setInput(IEditorInput input) {
stopListening();
editorInput = (MyEditorInput) input;
startListening();
public IEditorInput getEditorInput() {
return editorInput;
public Diagram getDiagram() {
//insure editor input has a diagram property
//or use adapters
return editorInput.getObject().getDiagram();
protected void initializeGraphicalViewerContents() {
//or use adapters
getDiagramGraphicalViewer().setContents(
editorInput.getObject().getDiagram());
initializeContents(getDiagramEditPart());
Et voila ! It works for me. I hope it will help.
Best regards.
Le 18/02/2010 16:11, Giovanni a écrit :
> Hi Ali,
> Thank you
> Best regards,
> Giovanni.
Re: GMF Diagram without Resource? [message #515959 is a reply to message #515953] Mon, 22 February 2010 05:59 Go to previous messageGo to next message
HI Ali,
thank you very much, I really appreciate your help.
Giovanni.
Re: GMF Diagram without Resource? [message #516025 is a reply to message #515959] Mon, 22 February 2010 09:04 Go to previous messageGo to next message
You welcome,
It seems like we are trying to make the same thing with GMF. I am
combining GMF with CNF to make multi-views modeler (see
http://vimeo.com/8928764). If this the case, maybe we can share our
experience. I have solved many of my issues but it remains lot of issues
I did not solved. I have posted several questions and had no answers, so
I spent hours at debugging to solve my problems. Indeed, I had to modify
the regular GMF flow, and a big part of the resulting flow is automated
through modified xpand templates.
Ali.
Le 22/02/2010 11:59, Giovanni a écrit :
> HI Ali,
> Giovanni.
Re: GMF Diagram without Resource? [message #516060 is a reply to message #516025] Mon, 22 February 2010 11:02 Go to previous messageGo to next message
Ali,
I've seen your video: very good job, very interesting, especially your use of xPand templates, which I don't know.
My needs are simpler than yours; I'm just trying to show in a Model Navigator (CNF based, of course) ONLY my model objects, not annoying Diagram, Shape, Node and so on, which are provided in the GMF-generated Project Explorer. Especially I don't want to display files.
My Model Navigator shows a statical and hierarchical folder structure, initially empty; then, I generate my model on-the-fly, using only standard EMF methods (XYZFactory.eINSTANCE.createXyz(), etc.) invoked by context menu on my Tree. The last action I want to provide is "Open Diagram", which has to take my model as root element and finally open the GMF-generated graphical editor: that's why I pose the initial question of this thread, 'cause I want to avoid to create a project file, until it's strictly necessary.
That said, if you think I can help you in any manner, I'll be happy to collaborate: this forum is a little...er, greedy of answers, so I hope we can change this.
Giovanni.
Re: GMF Diagram without Resource? [message #516077 is a reply to message #516060] Mon, 22 February 2010 12:16 Go to previous messageGo to next message
Thx Giovanni,
In case you still looking forward to open your diagram, here is the
trick (to complete the previous example I gave you):
1. In your plugin.xml:
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:org.eclipse.ui.popup.any?after=additions ">
<command
commandId="qualified.name.openDiagram"
label="Open Diagram"
style="push">
<visibleWhen
checkEnabled="false">
<with
variable="selection">
<count
value="1">
</count>
<iterate>
<adapt
type="qualified.name.to.MyObject">
</adapt>
</iterate>
</with>
</visibleWhen>
</command>
</menuContribution>
</extension>
<extension
point="org.eclipse.ui.commands">
<command
id="qualified.name.openDiagram"
name="Open Diagram Command">
</command>
</extension>
<extension
point="org.eclipse.ui.handlers">
<handler
class="qualified.name.commands.OpenDiagramHandler"
commandId="qualified.name.openDiagram">
</handler>
</extension>
2. Implement the Open Diagram Handler
package qualified.name.commands;
import org.eclipse.core.commands.AbstractHandler;
import org.eclipse.core.commands.ExecutionEvent;
import org.eclipse.core.commands.ExecutionException;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.handlers.HandlerUtil;
public class OpenDiagramHandler extends AbstractHandler {
public Object execute(ExecutionEvent event) throws ExecutionException {
ISelection selection = HandlerUtil.getCurrentSelection(event);
if (!(selection instanceof IStructuredSelection)) return null;
if (!(((IStructuredSelection)selection).getFirstElement() instanceof
MyObject)) return null;
MyObject myObject = (MyObject)
((IStructuredSelection)selection).getFirstElement();
IWorkbenchPage page =
HandlerUtil.getActiveWorkbenchWindow(event).getActivePage();
try {
page.openEditor(new MyEditorInput(myObject), MyDiagramEditor.ID);
} catch (PartInitException e) {
e.printStackTrace();
return null;
return null;
Hope it will help.
Ali.
Le 22/02/2010 17:02, Giovanni a écrit :
> Ali,
> we can change this.
> Best regards,
> Giovanni.
Re: GMF Diagram without Resource? [message #516209 is a reply to message #516077] Tue, 23 February 2010 03:43 Go to previous messageGo to next message
Thx Ali,
now your example is complete; I'll try it, and I'll give a feedback to you and to the newsgroup.
Giovanni.
Re: GMF Diagram without Resource? [message #533861 is a reply to message #516209] Mon, 17 May 2010 06:17 Go to previous message
I'm trying to implement the preceding example, but
when I execute the code, I get the following error: Could not open the editor: Editor could not be initialized.
This is the stackTrace:
!ENTRY org.eclipse.ui 4 0 2010-05-17 12:13:31.548
!MESSAGE Unable to create editor ID qbxtool.diagram.part.QbxCustomDiagramEditorID: Editor could not be initialized.
!STACK 0
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor$1.run(DiagramDocumentEditor.java:131)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:140)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at it.theorematica.qbx.navigator.handlers.OpenDiagramHandler.ex ecute(OpenDiagramHandler.java:95)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:294)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:770)
at org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:756)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:746)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at qbxtool.base.Application.start(Application.java:25)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
When I write the code from "MyEditor" class (method
//or use adapters
Eclipse complains: The method initializeContents(EditPart) from the type DiagramEditor is not visible.
Right, it is private; so, how can I initialize my custom editor?
Thanks, regards
Previous Topic:Problem with Outline view
Next Topic:Mixing between packages
Current Time: Wed May 22 19:53:04 EDT 2013
Powered by FUDForum. Page generated in 0.02765 seconds
