| Huge memory consumption of Eclipse Infocenter [message #475233] |
Tue, 10 March 2009 11:11  |
Niina Känsälä Messages: 4 Registered: July 2009 |
Junior Member |
I'm struggling with large memory consumption of Eclipse Infocenter. We
have a Infocenter library with 6 books, containing 12 000 pages
altogether. There are 4 million hits / 34 000 visits per month.
Allocated memory to eclipse is -vmargs -Xmx1536m (out of 4GB total in
server), but it is still running out of memory:
java.lang.OutOfMemoryError: Java heap space
Operating system is Red Hat Enterprise Linux ES release 4, eclipse package
version 3.4 and help plugin
org.eclipse.help.base_3.3.101.M20080728_34x.jar
Can it be true that standalone Infocenter really requires over 1536M
memory? Is there any recommended value?
For me it also seems that there might be some memory leak since the memory
consumption slightly grows until the maximum is reached (takes 24 hours or
so).
One thing that I found is setting locales (-nl en -locales en), but
testing didn't provide too convincing results.
I'd appreciate any help. Thanks!
| Re: Huge memory consumption of Eclipse Infocenter [message #623243 is a reply to message #475233] |
Tue, 10 March 2009 13:32  |
Chris Goldthorpe Messages: 815 Registered: July 2009 |
It should not require that much memory. Setting the locales should help
the situation because otherwise a search index will be built for every
locale used by clients of the infocenter. Based on your description of
the number of hits it does sound like a leak, I'm not aware of any other
infocenter with that many users. Do you have access to any tools that
you can hook up to your infocenter such as YourKit which you could use
to measure the memory use?
Niina Känsälä wrote:
> package version 3.4 and help plugin
> memory consumption slightly grows until the maximum is reached (takes 24
> hours or so).
FUDForum. Page generated in 0.06569 seconds
