Home » Eclipse Projects » Eclipse Platform » How to Hide import/export function in context menu
How to Hide import/export function in context menu [message #533114] Wed, 12 May 2010 05:52 Go to next message
Mallikarjun  is currently offline Mallikarjun
How to hide import/export function in context menu of Project Explorer, Package Explorer, Navigator...
Sample code using activities, but cannot disable
<extension
point="org.eclipse.ui.activities">
<activityPatternBinding
activityId="com.object.ide.rcp.hide.aptana.ui"
isEqualityPattern="true"
pattern="test/com.test.command1">
</activityPatternBinding>
<category
id="com.test.commands.category"
name="Command 1">
</category>
</extension>
regards,
Arjun.
[Updated on: Wed, 12 May 2010 07:47]
Report message to a moderator
Re: How to Hide import/export function in context menu [message #533208 is a reply to message #533114] Wed, 12 May 2010 10:54 Go to previous messageGo to next message
Francis Upton is currently offline Francis Upton
I forget the incantation, but this has been answered a few times in the forums before, you should search for it.
Re: How to Hide import/export function in context menu [message #533294 is a reply to message #533208] Thu, 13 May 2010 01:03 Go to previous message
I am not finding that.
Any help in finding the solution is highly appreciated. Smile
Previous Topic:Retrieve feature plugins
Next Topic:eclipse debugger: current instruction pointer problem.
Current Time: Thu May 23 13:37:11 EDT 2013
Powered by FUDForum. Page generated in 0.01611 seconds
