Home » Eclipse Projects » Riena » How Can I Remove / Modify Riena Logo?(Modfiy Riena Logo)
How Can I Remove / Modify Riena Logo? [message #531424] Tue, 04 May 2010 16:14 Go to next message
Uwe Hehn is currently offline Uwe Hehn
Hi!
I consider using Riena for a "standard" client-server business application.
I hope that I will suffice with Rienas UI-possibilites.
However, I need to remove or replace Rienas logo.
Is this possible?
Thx,
Uwe
Re: How Can I Remove / Modify Riena Logo? [message #531430 is a reply to message #531424] Tue, 04 May 2010 16:42 Go to previous messageGo to next message
Christian Campo is currently offline Christian Campo
Am 04.05.10 22:14, schrieb Uwe Hehn:
> Hi!
> Is this possible?
> Thx,
> Uwe
Hi Uwe,
thats pretty easy. Look at the class RienaDefaultTheme for IMAGE_LOGO. Write your own Theme (subclassing the existent),
overwrite the IMAGE_LOGO and add it to an icons directory for which you need to an extension for extension point
org.eclipse.riena.ui.swt.imagePaths
if you need help with that let me know
christian
Re: How Can I Remove / Modify Riena Logo? [message #531473 is a reply to message #531430] Wed, 05 May 2010 03:28 Go to previous messageGo to next message
Hi Christian,
thank you for your quick reply!
I have that gut feeling that I'm going to be a Riena Fan! Wink
Uwe
p.s. It worked like a charm!
[Updated on: Wed, 05 May 2010 16:02]
Report message to a moderator
Re: How Can I Remove / Modify Riena Logo? [message #532136 is a reply to message #531473] Fri, 07 May 2010 06:01 Go to previous message
Am 05.05.10 09:28, schrieb Uwe Hehn:
> Hi Christian,
> I have that gut feeling that I'm going to be a Riena Fan! ;)
> Uwe
If you need more help, let us know
christian
Re: How Can I Remove / Modify Riena Logo? [message #585220 is a reply to message #531424] Tue, 04 May 2010 16:42 Go to previous message
> Hi!
> Is this possible?
> Thx,
> Uwe
Hi Uwe,
christian
Re: How Can I Remove / Modify Riena Logo? [message #585263 is a reply to message #531430] Wed, 05 May 2010 03:28 Go to previous message
Hi Christian,
Uwe
Re: How Can I Remove / Modify Riena Logo? [message #585359 is a reply to message #585263] Fri, 07 May 2010 06:01 Go to previous message
> Hi Christian,
> Uwe
christian
Previous Topic:Riena on server-side with DI
Next Topic:Riena & Formtoolkit
Current Time: Tue May 21 22:13:22 EDT 2013
Powered by FUDForum. Page generated in 0.02639 seconds
