Home » Eclipse Projects » Marketplace Client Project » Marketplace Client Questions
Marketplace Client Questions [message #532032] Thu, 06 May 2010 16:05 Go to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
We are starting to look at marketplace client in Helios. Have a few questions.
1. The install button for our product (Oracle Enterprise Pack for Eclipse - OEPE) is not enabled in the marketplace client. What is missing from our listings?
2. We have three listings for versions of OEPE that target different versions of Eclipse (3.4, 3.5 and 3.6). All three listings show up when we search from Helios. We'd like only the appropriate one to show up. Is there something we need to setup in our metadata to make this happen or does the client not perform this sort of filtering yet?
- Konstantin
[Updated on: Thu, 06 May 2010 16:11]
Report message to a moderator
Re: Marketplace Client Questions [message #532245 is a reply to message #532032] Fri, 07 May 2010 12:36 Go to previous messageGo to next message
Ian Skerrett is currently offline Ian Skerrett
Konstantin Komissarchik wrote on Thu, 06 May 2010 16:05
Have you added the feature IDs? Look here for more info http://marketplace.eclipse.org/quickstart
The client will show all the data from the Marketplace server. However, it will only show the install button for those with feature IDs.
Re: Marketplace Client Questions [message #534379 is a reply to message #532245] Tue, 18 May 2010 18:00 Go to previous message
Thanks, Ian. We were able to get the install button to enable by entering feature ids in the listing. I have opened a bug to track the lack of filtering in MPC. This seems like a major outage considering that we cannot expect that all listing in the Marketplace will be compatible with all versions of Eclipse on all operating systems.
Bug 313449 - Marketplace client needs to filter out incompatible software
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313449
Previous Topic:UI Feedback: Why modal Dialog?
Next Topic:Marketplace Client Project
Current Time: Sun May 19 09:28:46 EDT 2013
Powered by FUDForum. Page generated in 0.02118 seconds
