Home » Eclipse Projects » Eclipse Platform » Why does Junit Plugin Test launch a workspace?(Workspace is launched when executing Junit plugin test)
Why does Junit Plugin Test launch a workspace? [message #531973] Thu, 06 May 2010 12:07 Go to next message
Tom Missing name is currently offline Tom Missing name
I'm using Eclipse 3.5x and I'm executing a JUnit Plugin Test using Junit4. I'm testing plugin projects with no UI and I've deselected the Run in UI Thread. Each time I execute the test a new workspace is launched for the duration of the test.
Is this just the way it works or is there a way to have it not launch the new workspace?
T
Re: Why does Junit Plugin Test launch a workspace? [message #532003 is a reply to message #531973] Thu, 06 May 2010 13:52 Go to previous message
Paul Webster is currently offline Paul Webster
> the new workspace?
Workspace (just your file system), or you mean workbench (what you need
to get a workbench window)? On the Main tab in your Junit launch
config, what happens if you select Run an Application and then pick [No
Application] - Headless mode?
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Problem with Progress View (when Running Jobs)
Next Topic:eclipse v3.4 API to Get List of Installed features
Current Time: Wed May 22 09:58:05 EDT 2013
Powered by FUDForum. Page generated in 0.01698 seconds
