| Problem installing Zend PHP Debugger [message #531638] |
Wed, 05 May 2010 12:15  |
Andrew Jones Messages: 5 Registered: May 2010 |
Junior Member |
I have successfully installed the Aptana Studio plugin, and the PHP IDE for Aptana.
When I try to install the Zend PHP Debugger plugin for Aptana I get the following error:
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.zend.php.debug.debugger,5.3.7.v20091116
No repository found containing: osgi.bundle,org.zend.php.debug.debugger.linux.x86,5.3.7.v200 91116
No repository found containing: org.eclipse.update.feature,org.zend.php.debug_feature,5.3.7. v20091116
Any ideas? I've *almost* got a perfect setup.
Thanks In Advance
Andrew Jones
| Re: Problem installing Zend PHP Debugger [message #532742 is a reply to message #531736] |
Tue, 11 May 2010 01:55  |
Walter Harley Messages: 847 Registered: July 2009 |
Andrew Jones wrote:
> No responses :( Would this be better posted on an Aptana forum? IMHO
> it could be either Eclipse or Aptana causing the issue, but I honestly
> think it Eclipse?
> Regards
> Andrew
Why do you think it is Eclipse? From the error message, it sounds like you are
trying to install some software that requires some other bundles that you have
not installed or specified a repository for.
FUDForum. Page generated in 0.11328 seconds
