Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help with MenuItem.setAccelerator() on OS X(Can't distinguish shifted and non-shifted minus character)
Help with MenuItem.setAccelerator() on OS X [message #531391] Tue, 04 May 2010 13:23 Go to next message
Doug M is currently offline Doug M
I would like to specify that cmd-minus is the key for a "zoom out" menu item. Using
item.setAccelerator(SWT.MOD1 | '-')
shows the correct command glyphs in the menu item. However, it responds to both cmd-minus and cmd-shift-minus (that's cmd-underline).
I want it to respond only to cmd-minus.
If I try different base keys, the shifted and non-shifted versions are correctly distinguished. For example,
item.setAccelerator(SWT.MOD1 | 'd');
responds only to cmd-d, and
item.setAccelerator(SWT.SHIFT | SWT.MOD1 | 'd');
responds only to cmd-shift-d, both showing correct glyphs in the menu item.
I tried SWT.KEYCODE_BIT with the actual keycode, but that also fails to distinguish minus and underline.
Can anyone explain, or suggest a solution?
TIA,
Doug
Re: Help with MenuItem.setAccelerator() on OS X [message #531577 is a reply to message #531391] Wed, 05 May 2010 08:54 Go to previous message
Praveen  is currently offline Praveen
Member
It sounds like a bug to me. Can you raise a bug request at
https://bugs.eclipse.org/bugs/
Praveen.
Previous Topic:Problem with SWT Standalone app on Solaris
Next Topic:icons in Combo...
Current Time: Tue May 21 12:42:42 EDT 2013
Powered by FUDForum. Page generated in 0.02150 seconds
