Home » Eclipse Projects » Standard Widget Toolkit (SWT) » xpath
xpath [message #530802] Sat, 01 May 2010 02:34 Go to next message
Filip is currently offline Filip
Hello, I have a problem with using xpath function "matches". I guess
it's the regexp problem, but I have tried almost everything. Calling
function "contains" works fine, but calling "matches" throws
org.mozilla.xpcom.XPCOMException: The function "evaluate" returned an
error condition (0x805b0033). I cant find detail of the exception
enywhere.
I am using xulrunner-sdk-1.9.1.3-win32. Are all functions from
http://www.w3.org/2005/xpath-functions supported?
When you call "xpath.evaluate" with "expr" in the snippet below, it
works, but using "expr2" throws exception.
Any ideas?
Thanks for reply.
Here's my snippet
public class XPath {
static Browser browser;
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new GridLayout(2, true));
shell.setText("Use Mozilla's Design Mode");
try {
browser = new Browser(shell, SWT.MOZILLA);
} catch (SWTError e) {
System.out.println("Could not instantiate Browser: " +
e.getMessage());
return;
browser.setLayoutData(new GridData(GridData.FILL,
GridData.FILL, true, true, 2, 1));
Button searchButton = new Button(shell, SWT.PUSH);
searchButton.setText("Search");
searchButton.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event event) {
search();
browser.setJavascriptEnabled(false);
browser.setUrl("http://www.google.com");
shell.setSize(400, 400);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
public static boolean search() {
nsIWebBrowser webBrowser = (nsIWebBrowser)
browser.getWebBrowser();
if (webBrowser == null) {
System.out.println("Could not get the nsIWebBrowser from
the Browser widget");
return false;
nsIDOMWindow window = webBrowser.getContentDOMWindow();
nsIDOMDocument document = window.getDocument();
nsIDOMXPathEvaluator xpath = (nsIDOMXPathEvaluator)
document.queryInterface(nsIDOMXPathEvaluator.NS_IDOMXPATHEVA LUATOR_IID);
nsIDOMXPathNSResolver res = xpath.createNSResolver(document);
res.lookupNamespaceURI("http://www.w3.org/2005/xpath-
functions");
String expr = "//input[contains(@name,'q')]";
String expr2 = "//input[matches(@name,\"[q]{1}\")]";
nsISupports obj = xpath.evaluate(expr2,
document,
res,
nsIDOMXPathResult.UNORDERED_NODE_ITERATOR_TYPE,
null);
nsIDOMXPathResult result = (nsIDOMXPathResult)
obj.queryInterface(nsIDOMXPathResult.NS_IDOMXPATHRESULT_IID) ;
nsIDOMNode node;
int i = 0;
while((node = result.iterateNext()) != null) {
System.out.println(node.getNodeName());
System.out.println(i++);
return true;
[Updated on: Sat, 01 May 2010 02:34]
Report message to a moderator
Re: xpath [message #531328 is a reply to message #530802] Tue, 04 May 2010 10:38 Go to previous message
Grant Gayed is currently offline Grant Gayed
Your post on the mozilla newsgroup is more likely to be seen by someone
that's familiar with this. For anyone that's interested the link is
http://groups.google.com/group/mozilla.dev.embedding/browse_ thread/thread/fa23a0634d881ba7# .
Grant
"Filip" <filip.pekarek@gmail.com> wrote in message
news:hrgi0r$gp2$1@build.eclipse.org...
> enywhere.
> Any ideas?
> Thanks for reply.
> Here's my snippet
> public static void main(String[] args) {
> try {
> e.getMessage());
> return;
> search();
> shell.open();
> display.sleep();
> display.dispose();
> return false;
> functions");
> document,
> res,
> null);
> nsIDOMNode node;
> int i = 0;
> return true;
Previous Topic:Is it possible to use combo with cascade behavior ?
Next Topic:Redirecting Scroll Wheel Events
Current Time: Tue May 21 23:05:27 EDT 2013
Powered by FUDForum. Page generated in 0.01470 seconds
