Home » Modeling » OCL » Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #530872] Sun, 02 May 2010 05:39 Go to next message
Ed Merks is currently offline Ed Merks
--------------060100020905060507010101
Content-Type: text/plain; charset=UTF-8; format=flowed
Juan,
Probably the new validation support added to EMF along with the OCL
project's exploitation of it will be of interest:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701>
I think Ed Willink documented how to take advantage of that, but I
couldn't find it on the OCL wiki, so I've added the OCL newsgroup to the
"to" list of the reply.
Ed
Juan Cadavid wrote:
> Hi Ecore Tools dev team,
> First of all I want to congratulate you for the tool which keeps
> getting better every time :)
> I'd like to ask you about the plans to integrate Ecore Tools with MDT
> OCL. Is this going to be done through the offered components in EMF
> Validation or is the component going to provide its own validation
> mechanism to work with OCL? You mention in the wiki plans to provide
> integration with EMF Validation, but I don't see any open bug for
> that; however https://bugs.eclipse.org/297650 talks about integration
> with org.eclipse.ocl. What is the goal of this integration? Is this
> documented anywhere?
> Thanks a lot for your help!
> -Juan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Juan,<br>
<br>
project's exploitation of it will be of interest:<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701">https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701</a><br>
</blockquote>
the "to" list of the reply.<br>
<br>
Cheers,<br>
Ed<br>
<br>
<br>
Juan Cadavid wrote:
<blockquote cite="mid:hrihss$kmn$1@build.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
integration with EMF Validation, but I don't see any open bug for that;
however <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/297650">https://bugs.eclipse.org/297650</a> talks about integration with
<br>
<br>
<br>
<br>
-Juan
<br>
</blockquote>
</body>
</html>
--------------060100020905060507010101--
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #531131 is a reply to message #530872] Mon, 03 May 2010 15:44 Go to previous messageGo to next message
Hi Ed, Juan
The write up is at http://wiki.eclipse.org/MDT/OCLinEcore
The first representation part is still valid.
The second editing part is not. It was written about six weeks ago since
when things have moved on a lot.
MDT/OCL 3.0.0M7 (on Wednesday) will include Xtext-based 'example'
editors for
- CompleteOCL which provides a OCL document to complement a meta-model
- OCLinEcore which provides a compound Ecore and OCL textual language
that may optional be loaded from/saved to an *.ecore file
- EssentialOCL a single expression for use in pop-ups
- OCLstdlib to define the OCL standard library
Watch this space/the Wiki for a revised write-up.
NB. The examples do not ship in the Helios Modeling EPP bundle, so you
need to load them from the MDT/OCL Update Site. Hopefully by Helios we
will have sorted out visibility through the Modeling Discovery UI.
Ed Willink
On 02/05/2010 10:39, Ed Merks wrote:
> Juan,
> Cheers,
> Ed
>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #532135 is a reply to message #531131] Fri, 07 May 2010 05:53 Go to previous messageGo to next message
Heiko is currently offline Heiko
Member
Hi Ed,
today I try to follow your wiki entry.
But I fails in the beginning.
After installing Eclipse 3.6M7 and MDT/OCL 3.0M7 I generate the Library
Example and try to open the ecore model with the OCLinEcore Editor.
I've got an event loop exception:
eclipse.buildId=I20100429-1549
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri May 07 11:39:02 CEST 2010
Unhandled event loop exception
java.lang.AssertionError: Cyclic resolution of lazy links :
TypedTypeRefCS.type->TypedTypeRefCS.type
org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObjec t(LazyLinkingResource.java:76)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObje ct(ResourceSetImpl.java:219)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 202)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 262)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(Ba sicEObjectImpl.java:1483)
org.eclipse.ocl.examples.xtext.base.baseCST.impl.TypedTypeRe fCSImpl.getType(TypedTypeRefCSImpl.java:96)
org.eclipse.ocl.examples.xtext.base.scoping.TypedTypeRefScop eAdapter.createContents(TypedTypeRefScopeAdapter.java:36)
org.eclipse.ocl.examples.xtext.base.scope.AbstractScopeAdapt er.getInclusiveInheritedContents(AbstractScopeAdapter.java:1 18)
org.eclipse.ocl.examples.xtext.base.scope.FilteredAccesses.a ddElementsOfScope(FilteredAccesses.java:58)
org.eclipse.ocl.examples.xtext.oclinecore.scoping.ClassScope Adapter.addInheritedContents(ClassScopeAdapter.java:67)
org.eclipse.ocl.examples.xtext.oclinecore.scoping.ClassScope Adapter.createContents(ClassScopeAdapter.java:59)
at org.eclipse.ocl.examples...........
Is it a bug, or what do I make wrong?
Greetings
Heiko
Am 03.05.2010 21:44, schrieb Ed Willink:
> Hi Ed, Juan
> editors for
> Regards
> Ed Willink
>> Juan,
>> Cheers,
>> Ed
>>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #532278 is a reply to message #532135] Fri, 07 May 2010 14:02 Go to previous message
Hi Heiko
I'm afraid that installing the Xtext editors is fraught with many
difficulties.
The underlying Xtext APIs changed between M6 and M7 so that an MDT/OCL
M7a is imminent to ensure M7 coherence.
Last night the M7 plugins were not yet in the staging area so installing
the trial M7a grabbed incompatible Xtext M6.
The load of *.ecore is limited to rather simple (no references to
another model) Ecore files. Bug already fixed, but not in M7a, which was
enough of a build trial without fixing bugs.
I'm afraid that in M7 the editors are a bit of a taster for treats in store.
Ed Willink
On 07/05/2010 10:53, Heiko wrote:
> Hi Ed,
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Greetings
> Heiko
>> Hi Ed, Juan
>> editors for
>> Regards
>> Ed Willink
>>> Juan,
>>> Cheers,
>>> Ed
>>>> -Juan
Previous Topic:Cannot find operation alloOwnedElements()
Next Topic:What's the way to get Operation object from a message object
Current Time: Mon May 20 15:21:49 EDT 2013
Powered by FUDForum. Page generated in 0.01723 seconds
