Home » Eclipse Projects » Equinox » ClassNotFoundException: org.apache.commons.logging.Log
ClassNotFoundException: org.apache.commons.logging.Log [message #530066] Wed, 28 April 2010 07:22
fsf_matt  is currently offline fsf_matt
Hi all,
I'm having a problem with a bundle that is loading a serialized object from a resource file inside the bundle jar. The object is a JasperReport, in a *.jasper file.
I've got a bundle containing commons logging, made with the New > Project > Plugin-in from Existing JAR Archives running in the framework. In trying to find which bundle was missing commons logging I added an Import-Package: org.apache.commons.logging to the manifest of all of the bundles, this did not change things.
Something odd I have noticed is that when I add the Import-Package to the offending project, an entry appears in the Plug-in Dependencies section of the project that references [program files]\eclipse\plugins\org.apache.commons.logging.[version]. jar, instead of the project that wraps the commons logging library, could this be the problem? Is there some way to stop eclipse interpreting it like this?
Here is the stack trace:
java.lang.NoClassDefFoundError: Lorg/apache/commons/logging/Log;
at java.lang.Class.getDeclaredFields0(Native Method)
at java.lang.Class.privateGetDeclaredFields(Unknown Source)
at java.lang.Class.getDeclaredField(Unknown Source)
at java.io.ObjectStreamClass.getDeclaredSUID(Unknown Source)
at java.io.ObjectStreamClass.access$700(Unknown Source)
at java.io.ObjectStreamClass$2.run(Unknown Source)
at java.io.ObjectStreamClass.<init>(Unknown Source)
at java.io.ObjectStreamClass.lookup(Unknown Source)
at java.io.ObjectStreamClass.initNonProxy(Unknown Source)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
at java.io.ObjectInputStream.readSerialData(Unknown Source)
at java.io.ObjectInputStream.readArray(Unknown Source)
at java.io.ObjectInputStream.defaultReadObject(Unknown Source)
at net.sf.jasperreports.engine.base.JRBaseDataset.readObject(JR BaseDataset.java:401)
at java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
at net.sf.jasperreports.engine.base.JRBaseReport.readObject(JRB aseReport.java:812)
at java.io.ObjectInputStream.readObject(Unknown Source)
at report.ChildAssessmentReportGenerator.loadReport(ChildAssess mentReportGenerator.java:160)
at report.ChildAssessmentReportGenerator.makeReport(ChildAssess mentReportGenerator.java:78)
at gui.reportscreen.ReportPanel.actionPerformed(ReportPanel.jav a:298)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unk nown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.logging.Log
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:448)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 72 more
Any Ideas?
Thanks.
Matt.
Previous Topic:Integration of Equinox and Liferay
Next Topic:[p2] How to manage mandatory and optional updates?
Current Time: Tue Jun 18 02:39:21 EDT 2013
Powered by FUDForum. Page generated in 0.02454 seconds
