Home » Eclipse Projects » EPP » changes in UDC in Helios?(and some small statistics from UDC.)
icon6.gif  changes in UDC in Helios? [message #530033] Wed, 28 April 2010 05:05 Go to next message
David  is currently offline David
Member
Has there been any work done in UDC for the Helios release?
As i am looking into the Helios release now and i need to find out if something has happened with UDC. I saw the post about possible activites with the Mylyn capture but did that lead to anything?
Some small statistics from us:
I got 128646 rows of data uploaded since first of November .
36 unique individuals has uploaded data, i assume quite a lot has declined to upload data. We have 172 machines that has Eclipse 3.5 so not that good penetration.
Its recorded some 36696 errors where "Unhandled event loop exception" is on top with 9142 hits. I think this has to do with to little ram on the machines (I have seen this on my own machines a couple of times) Without UDC we would not have known.
best regards
David
[Updated on: Wed, 28 April 2010 07:04]
Report message to a moderator
Re: chages in UDC in Helios? [message #530431 is a reply to message #530033] Thu, 29 April 2010 11:44 Go to previous messageGo to next message
Wayne Beaton is currently offline Wayne Beaton
There has been no significant work done on the UDC for Helios. Minor bug
fixes has been all we've had time for.
Can you post a stack trace for these errors? Or open a bug report? Or
point me to an existing bug report (if any)? I'm not sure how UDC might
be responsible for an "Unhandled event loop exception".
Wayne
> best regards
> David
Re: chages in UDC in Helios? [message #530563 is a reply to message #530431] Fri, 30 April 2010 03:57 Go to previous messageGo to next message
Member
ok, no idea in persuing updating it further then from my side.
When i said the top error is the top error that UDC has reported to the database from the users.
I haven't dug deeper in it yet, i need to get out the top user who has this fault and go to him and grab the log files.
So the UDC is not responsible for the top 1 error!
That was one of the enhancement that could be done to UDC though, grab the stack trace and attach it when it found an error. Now we just have the title of the stack trace and it can possibly come from multiple places. I looked into it and its possible but decided to not pursue it due to that i think it will be to intrusive for the developers, and that the stack trace is quite a lot of data for uploading, also new tables etc need to be created to hold the data.
If you have an solution to that request i am all ears, as it has helped us in many cases to get rid of bugs from our eclipse environment. In the beginning we had tons of errors from our version control plugins that we could fix due to that we analyzed the top error during the beta phase of introducing galileo.
Best regards
David
Re: chages in UDC in Helios? [message #530770 is a reply to message #530563] Fri, 30 April 2010 14:48 Go to previous message
We decided explicitly to not include the entire stack trace. We are
concerned about privacy and including the stack trace would require that
we do something clever to hide the names of classes and such that could
divulge too much information about the individual.
Wayne
> Best regards
> David
Re: chages in UDC in Helios? [message #580199 is a reply to message #530431] Fri, 30 April 2010 03:57 Go to previous message
Member
Best regards
David
Re: chages in UDC in Helios? [message #580218 is a reply to message #530563] Fri, 30 April 2010 14:48 Go to previous message
Wayne
> Best regards
> David
Previous Topic:chages in UDC in Helios?
Next Topic:Missing UDC data?
Current Time: Thu May 23 06:32:44 EDT 2013
Powered by FUDForum. Page generated in 0.01950 seconds
