Home » Eclipse Projects » Web Tools Project (WTP) » Failed to install Eclipse Java EE Developer Tools
icon5.gif  Failed to install Eclipse Java EE Developer Tools [message #525703] Wed, 07 April 2010 09:57 Go to next message
No real name is currently offline No real name
I was trying to install Eclipse Java EE Developer Tools from the 3.6m6 driver jst-sdk-buildrepo-S-3.2.0M6-20100315195309.zip
I got the following error message
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,javax.xml.soap,1.3.0.v200904281458
No repository found containing: osgi.bundle,org.eclipse.datatools.modelbase.dbdefinition,1.0 .2.v201002130228
No repository found containing: osgi.bundle,org.eclipse.datatools.modelbase.sql,1.0.4.v20100 2250945
Tried to found datatools.modelbase and couldn't figure out where to get it.
Can you please suggest? Thanks.
Samuel
Re: Failed to install Eclipse Java EE Developer Tools [message #529953 is a reply to message #525703] Tue, 27 April 2010 15:58 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> action=).
> .2.v201002130228
> it. Can you please suggest? Thanks.
> Samuel
Which repositories are you searching? You would almost certainly need
the corresponding wst repository as well as the repositories for the
projects normally listed as dependencies on our download page, DTP, GEF,
EMF, and XSD.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:No repository found at http://download.eclipse.org/webtools/updates
Next Topic:problems extending XMLMultipageEditorPart
Current Time: Tue May 21 04:02:21 EDT 2013
Powered by FUDForum. Page generated in 0.01593 seconds
