Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Blank DateTime widget
Blank DateTime widget [message #520145] Thu, 11 March 2010 05:08 Go to next message
No real name is currently offline No real name
I use the DateTime widget in my application.
I instanciate it as following:
new DateTime (parent, SWT.BORDER | SWT.DROP_DOWN);
Can I load this widget with no default value rather than the current date?
Re: Blank DateTime widget [message #520509 is a reply to message #520145] Fri, 12 March 2010 11:18 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
This is not currently supported, the existing request for this is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178362 .
Grant
<chewb0504@yahoo.fr> wrote in message news:hnafe7$chf$1@build.eclipse.org...
> Hello,
Re: Blank DateTime widget [message #521405 is a reply to message #520509] Wed, 17 March 2010 10:15 Go to previous messageGo to next message
Thx for the answer.
I will use the DateChooser component from nebula library.
Re: Blank DateTime widget [message #529252 is a reply to message #520509] Fri, 23 April 2010 11:08 Go to previous messageGo to next message
Eclipse User
Originally posted by: mike.dean.hsc.utah.edu
Is it possible to SET the DateTime to current? When I use this and a new
form is instantiated, it is already set to current time, but I want the user
to be able to refresh the widget to the current time.
- Mike
On 3/12/10 10:18 AM, in article hndph0$qke$1@build.eclipse.org, "Grant
Gayed" <grant_gayed@ca.ibm.com> wrote:
> Grant
>> Hello,
J. Michael Dean, M.D., M.B.A.
University of Utah School of Medicine
Salt Lake City, Utah
Re: Blank DateTime widget [message #529865 is a reply to message #529252] Tue, 27 April 2010 09:50 Go to previous message
To do this you need to get the current date/time from Java with a line like
below, and then set the DateTime control's values accordingly.
Calendar calendar = Calendar.getInstance();
Grant
"J. Michael Dean" <mike.dean@hsc.utah.edu> wrote in message
news:C7F7140E.3D138%mike.dean@hsc.utah.edu...
user
> - Mike
> > Hi,
> > Grant
> >> Hello,
date?
Previous Topic:Dropdown always above CCombo
Next Topic:Buttons don't display until window is resized
Current Time: Wed May 22 16:22:26 EDT 2013
Powered by FUDForum. Page generated in 0.02028 seconds
