| Installing AGF3D [message #529831] |
Tue, 27 April 2010 08:14  |
Jean-Paul de Vooght Messages: 20 Registered: April 2010 |
Junior Member |
Hello all!
I have successfully installed AMP on Eclipse 3.5.2 and noticed some errors on my escape tutorial using the Epidemic model prepared by Miles.
While installing the extra package over Help... Install New... selecting AGF3D, Eclipse returned
Cannot complete the install because one or more required items could not be found.
Software being installed: AMP AGF 3D (Incubation) 0.5.0.HEAD-17u47aVNT (org.eclipse.amp.agf3d.feature.group 0.5.0.HEAD-17u47aVNT)
Missing requirement: AMP AGF 3D (Incubation) 0.5.0.HEAD-17u47aVNT (org.eclipse.amp.agf3d.feature.group 0.5.0.HEAD-17u47aVNT) requires 'org.lwjgl 0.0.0' but it could not be found
Eclipse and I are not good friends and I could not find a simple way to add lwjgl such that the install is allowed be Eclipse.
Any ideas?
TIA
Jean-Paul
| Re: Installing AGF3D [message #530738 is a reply to message #530592] |
Fri, 30 April 2010 12:25   |
Miles Parker Messages: 1266 Registered: July 2009 |
Hey Jean-Paul,
Were you able to get the LWJGL update site? One you add that in, you can just select the LWJGL checkbox, install that, and then go back and select the AMP update site and add in the extension. Perhaps this new bit of documentation will help..
http://eclipse.org/amp/documentation/contents/Installation_G uide.html
BTW, I'm about to drop a new milestone probably today. This will be for version 0.7.0. BTW2, the interim releases are usually pretty stable too.
Also, I've been giving some thought to your use cases re: Slime Molds and I'll be returning to that soon. As I mentioned there are a lot of features that have been waiting in the wings.
Thanks for pointing out the issue with links I'll take a look. We don't have a "release" release yet.
cheers,
Miles
| Jean-Paul de_Vooght wrote on Fri, 30 April 2010 05:28 | I'll try to recall - it's been a few days now. But I recall
- downloading eclipse for Java 3.5.2
- adding the remote update link
http://download.eclipse.org/amp/updates/release
(it struck me that the URL points to release although it's label says milestones) from the page http://www.eclipse.org/amp/installing/updates.php
- found the epidemic article and imported the metaabm on a manually created project as per instruction
- then I paid attention to the errors on Epidemic3D.java in the generated code
- then re-checked the installer and noticed the optional parts (without paying attentio to the bottom note on LWJGL recommended)
How should I add it in Eclipse in such a way that Eclipse lets me install the optional component AGF3D from the installer? (optional question as this is more a newbie eclipse question
JP
| Re: Installing AGF3D [message #530845 is a reply to message #530814] |
Sat, 01 May 2010 14:33  |
Yes, there is a mis-match between the version that is there and the milestone. I assume you're using the milestone download?
In the latest version, I've removed the requirement that spaces have to have explicit agents, e.g. Location. But of course that's not backward compatible. I'm getting ready to post the next milestone probably on monday, but if you can't wait us the interim site at:
http://download.eclipse.org/amp/updates/interim/features/
FUDForum. Page generated in 0.01671 seconds
