Home » Modeling » AMW » Cannot find "Name Similarity" transformation in menu!
Cannot find "Name Similarity" transformation in menu! [message #528069] Mon, 19 April 2010 04:13 Go to next message
Alexey is currently offline Alexey
Member
Hallo again! Smile
I try to go through the first sample of AMW-use cases (persons 2 personsNew). And I can't find in menu the option "Name Similarity" for creating an appropriate AMW-modell.
All other options are there, except this one.
Could someone please help me?
Thanks a lot once again,
Alexey
[Updated on: Mon, 19 April 2010 04:29]
Report message to a moderator
Re: Cannot find "Name Similarity" transformation in menu! [message #528397 is a reply to message #528069] Tue, 20 April 2010 07:57 Go to previous message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del Fabro
Member
this transformation is not delivered with the plug-in, because it uses external APIs with different licences (wordnet API and another string matching API).
You can use "Name equality" instead (well it is simpler..), or add a hook by yourself in this transformation to call these or similar APIs.
Marcos.
Previous Topic:AMW Ecore metamodel
Next Topic:Cant create Weaving Model
Current Time: Tue May 28 08:36:16 EDT 2013
Powered by FUDForum. Page generated in 0.01523 seconds
