Home » Eclipse Projects » EclipseLink » How to approach data tracking?(So that updates to the database INSERT instead of UPDATE)
How to approach data tracking? [message #522017] Fri, 19 March 2010 12:14 Go to next message
Carlos Conti is currently offline Carlos Conti
Hi all,
I am newbie to JPA and have been developing an essay application for my organisation. Currently I am almost at the end of it, but there remains an issue regarding data tracking in the backend database.
Currently I have come to record data in a 'record per instance' manner. This model doesn't allow me to track changes in a userfriendly way. I can figure out tricky ways of doing it, if I must unavoidably stick to this way of doing things. However I am sure there must be an easier way to build it with another pk strategy.
I would like to adopt a double primarykey where in one field I would have my currently automatically created id (through an 'Identity' pk generation strategy), and in the second field I would have a DELETED flag such as {0,1}.
If possible I would appreciate if someone could give me a hint on how to get there.
Thanks in advance for your help!
Carlos.
Re: How to approach data tracking? [message #522040 is a reply to message #522017] Fri, 19 March 2010 09:34 Go to previous messageGo to next message
Tom Eugelink is currently offline Tom Eugelink
If your problem is solved by keeping a history of changes; Eclipselink supports storing old versions of a record in a separate history table, together with a valid from-until timestamp pair.
Tom
Re: How to approach data tracking? [message #522050 is a reply to message #522040] Fri, 19 March 2010 14:40 Go to previous messageGo to next message
Cool!, but where do you specify that?
I am using the JPA Eclipse IDE to write the ORM file, and so far haven't seen any reference to what you're saying. Could you tell me in which context must I define that? entity context?, persistence context?, I presume entitycontext...
should I create a secondary table for that? and then how do I specify I want to add an old record...
thanks!
Carlos.
Re: How to approach data tracking? [message #522085 is a reply to message #522050] Fri, 19 March 2010 12:26 Go to previous messageGo to next message
http://wiki.eclipse.org/Configuring_a_Descriptor_(ELUG)#Conf iguring_a_History_Policy
The history table is an exact copy of the actual table plus two fields. A new record is added to the history table as soon as the original record is updated. Works like a charm for me.
Tom
icon14.gif  Re: How to approach data tracking? [message #528278 is a reply to message #522085] Mon, 19 April 2010 18:12 Go to previous message
Cool Tom.
Thanks for your explanation. I'm sure I will be able to get forward.
Sorry for my late response.
Carlos.
Previous Topic:cascade delete not working when cache is active
Next Topic:Reading entity beans from Glassfish too slow
Current Time: Thu May 23 07:49:04 EDT 2013
Powered by FUDForum. Page generated in 0.01724 seconds
