Home » Eclipse Projects » Web Tools Project (WTP) » JSF/JSP 100% cpu/hang on content-assist(JSF/JSP 100% cpu/hang on content-assist)
JSF/JSP 100% cpu/hang on content-assist [message #527638] Thu, 15 April 2010 16:48 Go to next message
Jim Boden is currently offline Jim Boden
This works great in eclipse 3.3, but starting in 3.4 and 3.5, I see a big problem with trying to do content-assist (ctrl-space) on a jspx page. I've now found a repeatable work-around and break cycle so hopefully someone can help find the issue.
I see this on a project with about medium sized beans. I don't really see it on demo/small beans. So I'm editing a jspx file and get to a place like:
<h:outputText value="#{MyBean.
And right there, I click ctrl-space. Eclipse then pegs at 100% cpu for about 10-20 seconds, then comes back with the list of variables/methods.
Now I close eclipse and edit my faces-config.xml file with a text editor. I then restart eclipse and if I check the log file, I'll see exceptions about the faces-config.xml file resource out of sync. org.eclipse.core.internal.resources.ResourceException.
From here on out, the content-assist / autocomplete works great. If I ever click refresh (F5) on the project/faces file, it will refresh and go back to taking up high cpu.
So something about the exception must stop a type of validation that hangs the content-assist.
Anyone have an idea of what this could be?
Thanks!
Re: JSF/JSP 100% cpu/hang on content-assist [message #528858 is a reply to message #527638] Thu, 22 April 2010 03:53 Go to previous message
tux_linux is currently offline tux_linux
same here, working in nativ java. I have no sollution on this, but I think it's more a problem on java than on eclipse.
greets
Torsten
I never finish anyth...
Previous Topic:Excluding source code control folders from .war build
Next Topic:How to install XML Editors and Tools SDK into CDT/JDT install?
Current Time: Tue May 21 06:35:36 EDT 2013
Powered by FUDForum. Page generated in 0.07634 seconds
