Home » Eclipse Projects » Rich Client Platform (RCP) » How to share plugins between several applications?  () 1 Vote
How to share plugins between several applications? [message #526475] Sun, 11 April 2010 11:48 Go to next message
Andrey Pavlenko is currently offline Andrey Pavlenko
I'm developing several RCP applications and would like to store plugins, common to all applications, in an external folder, not in the MyApp/plugins folder. I'm trying to do this using the links directory in the following way:
I've created the following directory structure:
MyApp1
----plugins
----links
--------share.link
MyApp2
----plugins
----links
--------share.link
share
----eclipse
--------plugins
The files share.link have the following content: path=<absolute path to the share directory>
Put common plugins to the share/plugin directory.
Unfortunately, when I start my applications, the plugins from share/plugins are not loaded.
What am I doing wrong? Which eclipse plugin(s) handles the links folder and loads plugins, referenced by the .link files?
Thanks in advance.
[Updated on: Mon, 12 April 2010 02:09]
Report message to a moderator
Re: How to share plugins between several applications? [message #527207 is a reply to message #526475] Wed, 14 April 2010 09:11 Go to previous messageGo to next message
Wim Jongman is currently offline Wim Jongman
Hi Andrey,
Check this: http://www.eclipse.org/equinox/documents/quickstart.php
Best Regards,
Wim Jongman
-- BUFFERS=20 FILES=15 2nd down, 4th quarter, 5 yards to go!
(Eclipse Old Skool Quote Service)
> Hello,
> MyApp1
> ----plugins
> ----links
> --------share.link
> MyApp2
> ----plugins
> ----links
> --------share.link
> share
> ----plugins
share directory>
are not loaded.
> Thanks in advance.
Re: How to share plugins between several applications? [message #527211 is a reply to message #527207] Wed, 14 April 2010 09:51 Go to previous messageGo to next message
Hi Wim,
Thank you for the interesting link. As I understood from the article, the update configurator discovers all bundles, located in the plugins directory. Can I specify a different directory, or several directories, to discover?
Re: Re: How to share plugins between several applications? [message #527274 is a reply to message #527211] Wed, 14 April 2010 11:54 Go to previous messageGo to next message
Hi Andrey,
Yes you can. This is used frequently for the bundle sharing use case you
describe.
Best Regards,
Wim Jongman
-- Does fuzzy logic tickle?
> Hi Wim,
Re: Re: How to share plugins between several applications? [message #527320 is a reply to message #527274] Wed, 14 April 2010 15:57 Go to previous messageGo to next message
But how?
Re: Re: Re: How to share plugins between several applications? [message #527345 is a reply to message #527320] Wed, 14 April 2010 17:34 Go to previous messageGo to next message
Normally, you are responsible for installing, starting and stopping your
bundles. However, you can build an admin plugin to do this for you. One of
the bundles that does this is the org.eclipse.equinox.simpleconfigurator. If
you look in your eclipse configuration directory you will find and area for
this bundle which contains the bundles.info file. You can put a bundle in
this file and it will be loaded.
Please see this wiki text on P2 for some info on this file:
http://wiki.eclipse.org/Equinox_p2_Getting_Started
Contains other interesting information for your use case.
Best Regards,
Wim Jongman
-- Press any key to continue or any other key to quit...
> But how?
Re: Re: Re: How to share plugins between several applications? [message #527423 is a reply to message #527345] Thu, 15 April 2010 04:41 Go to previous message
I did it! Thank you very much, Wim!
Previous Topic:update RCP application problem
Next Topic:Define perspective from a saved perspective
Current Time: Tue Jun 18 03:54:57 EDT 2013
Powered by FUDForum. Page generated in 0.05981 seconds
