Home » Eclipse Projects » Buckminster dev » PDE's Export Target Wizard
PDE's Export Target Wizard [message #526563] Mon, 12 April 2010 06:00 Go to next message
Johannes Utzig is currently offline Johannes Utzig
I was just reading Chris' Blog entry about the new PDE's export target
wizard that allows the user to export a target definition to a certain
location.
http://aniszczyk.org/2010/04/09/pdes-export-target-wizard/
Would it be possible to reuse that headlessly in Buckminster?
That would go great with the Hudson integration.
The plugin already implements a 'Target Platform Publisher' that lets
you archive a directory that contains plugins and features.
The user names this Target Platform and is then able to reuse it
declarative in other build jobs.
Currently people already use target definition files to create a TP for
other build jobs (simply more convinient than mspecs), but so far it's
only possible with a hack:
1. Invoke buckminster with importtargetdefinition -A some.target
2. archive .metadata/org.eclipse.pde.core/.bundle-pool
This isn't exactly clean since it's fishing internal stuff from the
metadata.
So with this new export wizard available the hudson plugin could offer
much better support for the user. To create a target platform for other
build jobs, simply point to a *.target file and name the output. The
rest can be done automatically.
So, does anybody know if this functionality could be used in a headless
environment and integrated into buckminster?
Johannes
Re: PDE's Export Target Wizard [message #526595 is a reply to message #526563] Mon, 12 April 2010 07:45 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
Hi Johannes,
I saw that blog too. I think it definitely deserves an enhancement request in our bugzilla. The only thing I can see
that would prevent integration is if PDE didn't maintain the headless/UI separation for this new function. I think
that's unlikely though. The target definition stuff has been well designed so far.
- thomas
On 04/12/2010 12:00 PM, Johannes Utzig wrote:
> location.
> metadata.
> Best regards,
> Johannes
Re: PDE's Export Target Wizard [message #526601 is a reply to message #526595] Mon, 12 April 2010 07:51 Go to previous message
Ralf Ebert is currently offline Ralf Ebert
304062: Add option to importtargetdefinition to save the provisioned target platform to
some folder
https://bugs.eclipse.org/bugs/show_bug.cgi?id=304062
- Ralf
Read my Blog here: http://www.ralfebert.de/blog/
Follow me on Twitter here: http://twitter.com/ralfebert/
Previous Topic:Can Buckminster build eclipse cdt?
Next Topic:Buckminster and p2
Current Time: Tue May 21 19:14:07 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
