| Running TPTP tests from an external framework [message #52451] |
Wed, 01 February 2006 11:50  |
Hampus Edvardsson Messages: 2 Registered: July 2009 |
Junior Member |
I have a TPTP test suite in Eclipse that I run as part of a test
framework initiated from a unix command line.
I can start the tests by lauching Eclipse with the hyades
AutomationClientAdapter and generate a .execution file with the test
results. However, I have not been able to figure out how to read the
test status from this binary file and communicate the status back to my
test framework. Any ideas on how to do this?
In Eclipse, I can manually use TPTP to generate an HTML report from the
test execution. Is there any way to doing this from the command line?
/Hampus Edvardsson
FUDForum. Page generated in 0.01633 seconds
