| strange behaviour [message #524782] |
Fri, 02 April 2010 09:20  |
G Messages: 6 Registered: April 2010 |
Junior Member |
Hi !
I am running this code:
public class Test {
Persistence.createEntityManagerFactory("MyPersistenceUnit");
Then the environemnt outputs (near exactly):
run-single:
2010-4-2 0:35:05 javax.persistence.spi.PersistenceProviderResolverHolder$DefaultPersistenceProviderResolver log�
WARNING: javax.persistence.spi::No valid providers found using:�
WARNING: javax.persistence.spi::潲朮散汩灳攮灥牳楳瑥湣攮橰愮健牳楳瑥湣敐牯癩摥�
- jar:file:/D:/NetBeans/java3/modules/ext/eclipselink/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
- jar:file:/D:/Java/project%20workspace/Identity/dist/lib/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
- jar:file:/D:/Java/project%20workspace/Utilities/dist/lib/eclipselink-2.0.0.jar!/META-INF/services/javax.persistence.spi.PersistenceProvider�
Exception in thread "main" javax.persistence.PersistenceException: No Persistence provider for EntityManager named MyPersistenceUnit�
Java Result: 1
BUILD SUCCESSFUL (total time: 0 seconds)
Whats going on ?
I am using Netbeans 6.8.
Thanks !
[Updated on: Fri, 02 April 2010 09:22] Report message to a moderator
| Re: strange behaviour [message #524797 is a reply to message #524782] |
Fri, 02 April 2010 10:40   |
Christian Messages: 8 Registered: March 2010 |
Junior Member |
how looks your persistence.xml?
IMO a minimum version of a persistence.xml is needed, e.g.:
<?xml version="1.0" encoding="utf-8"?>
<persistence xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_2_0.xsd"
version="2.0" xmlns="http://java.sun.com/xml/ns/persistence">
<persistence-unit name="MyPersistenceUnit" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
</persistence-unit>
</persistence>
From now you can configure all in your java code or using the xml feature.
Hope this helps.
Best regards
Christian
[Updated on: Fri, 02 April 2010 10:40] Report message to a moderator
| Re: strange behaviour [message #524851 is a reply to message #524797] |
Fri, 02 April 2010 19:29   |
Junior Member |
Yes, the "error" appears provided the persistence.xml is present.
An interesting fact is that my code runs when in testcase and not in the main source code place.
E.g.
(in test case code)
void test(){
MainClass.main(null);
Note that the MainClass here corresponds to Test in the code from my last post.
[Updated on: Fri, 02 April 2010 19:30] Report message to a moderator
FUDForum. Page generated in 0.01786 seconds
