Home » Modeling » OCL » Adding OCL in a Ecore Metamodel(Adding OCL in a Ecore Metamodel)
| Adding OCL in a Ecore Metamodel [message #510994] |
Fri, 29 January 2010 08:26  |
Fernando Herrera Messages: 49 Registered: January 2010 |
Member |
Hi everyone!. I'm trying to add OCL for specify restrictions and derived references in my ecore metamodel (the mindmap). I'm reading the book Eclipse Modeling Project: A domain specific language toolkit. In Chapter 3, Gronback show how do this activity. The problem is I have done and review the book twice and Eclipse not generate the JET templates in the templates folder and the code derived from the OCL Statements in the class implementation. I checked the source and its the tutorial: Christian W. Damus, "Implementing Model Integrity in EMF with MDT OCL. Well, I tried do it whit the Eclipse modeling project version and the modeling version of Eclipse (both Galileo) and in the two cases it doesn't work. Can somebody tell me how to add OCL in the Ecore metamodel in these versions?
PS: I read anothers post with the same problem but I don't find any solution in the order to solve this problem. Is important for me, because I have to develop a plugin's series in the form of UML profiles for a specific language to represent collaborative business processes models between business partners and I must to implement restrictions in the differents metamodels using OCL
[Updated on: Fri, 29 January 2010 16:03] Report message to a moderator
| Re: Adding OCL in a Ecore Metamodel [message #511756 is a reply to message #511740] |
Tue, 02 February 2010 13:07   |
Christian W. Damus Messages: 550 Registered: July 2009 |
--=-X5L2viIqIB1HPlV6ENfo
Content-Type: text/plain
Hi, Fernando,
The article isn't obsolete: it still works just fine with EMF 2.3! :-P
It does happen to illustrate one of the risks inherent in using custom
templates, though: as EMF's generator framework evolves, one's custom
templates do need to be updated to pick up changes from the EMF
templates that they replace. The EMF team does a good job of ensuring
that its supported extension and override points continue to work, but
can't really do anything to help people like me who completely replace
the base templates.
Perhaps you'd like to help complete the more modern solution proposed in
http://bugs.eclipse.org/191689 ?
Christian
On Tue, 2010-02-02 at 12:00 -0500, Fernando Herrera wrote:
> I solve the problem. I looked for the samples of the book wich were in the org.eclipse.amalgam.examples.dsltk plugin and then I imported the mindmap example whitin the workspace and copy and paste the jet templates into my project. I think the templates from the tutorial are obsolote
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Fernando,<BR>
<BR>
The article isn't obsolete: it still works just fine with EMF 2.3! :-P<BR>
<BR>
It does happen to illustrate one of the risks inherent in using custom templates, though: as EMF's generator framework evolves, one's custom templates do need to be updated to pick up changes from the EMF templates that they replace. The EMF team does a good job of ensuring that its supported extension and override points continue to work, but can't really do anything to help people like me who completely replace the base templates.<BR>
<BR>
Perhaps you'd like to help complete the more modern solution proposed in http://bugs.eclipse.org/191689 ?<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-X5L2viIqIB1HPlV6ENfo--
| Re: Adding OCL in a Ecore Metamodel [message #511958 is a reply to message #511829] |
Wed, 03 February 2010 09:32   |
--=-y67yr2zACHJGnNBz6qFz
Hi, Ed,
Many thanks to you and Kenn for working so diligently on this. The
prospect of finally having a complete validation solution in Ecore is
very exciting! And no less exciting is parity of dynamic Ecore's
capabilities with generated models.
Christian
On Wed, 2010-02-03 at 06:42 +0000, Ed Willink wrote:
> Hi Fernando, Christian
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689 has just sprung
> back to life with the 3.6M6 API change deadline looming. Support for
> the new way of doing OCL constraints will appear in MDT/OCL CVS in the
> next week or two and will be available in the Eclipse M6 milestone and
> subsequently the Helios release.
> I'm sorry that in the interim the solutions are poorly described.
> Regards
> Ed Willink
> On 02/02/2010 20:29, Fernando Herrera wrote:
--------8<--------
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
Many thanks to you and Kenn for working so diligently on this. The prospect of finally having a complete validation solution in Ecore is very exciting! And no less exciting is parity of dynamic Ecore's capabilities with generated models.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
<A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689">https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689</A> has just sprung
Ed Willink
</PRE>
</BLOCKQUOTE>
<BR>
--------8<--------
</BODY>
</HTML>
--=-y67yr2zACHJGnNBz6qFz--
| Re: Adding OCL in a Ecore Metamodel [message #511959 is a reply to message #511958] |
Wed, 03 February 2010 09:36   |
Ed Merks Messages: 24547 Registered: July 2009 |
--------------040108050409040403090903
Content-Type: text/plain; charset=UTF-8; format=flowed
Christian,
Yes, it's yet another fairly well hidden gem in the collection of crown
jewels. :-P
Christian W. Damus wrote:
> Hi, Ed,
> Cheers,
> Christian
>> Regards
>> Ed Willink
> --------8<--------
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Christian,<br>
<br>
jewels. :-P<br>
<br>
<br>
<blockquote cite="mid:1265207545.7091.33.camel@cdamus-laptop"
type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta name="GENERATOR" content="GtkHTML/3.24.1.1">
Hi, Ed,<br>
<br>
capabilities with generated models.<br>
<br>
Cheers,<br>
<br>
Christian<br>
<br>
<br>
<blockquote type="CITE">
<pre>Hi Fernando, Christian
<a moz-do-not-send="true"
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689">https://bugs.eclipse.org/bugs/show_bug.cgi?id=191689</a> has just sprung
Ed Willink
</pre>
</blockquote>
<br>
--------8<--------
</blockquote>
</body>
</html>
--------------040108050409040403090903--
Current Time: Wed May 22 04:27:49 EDT 2013
Powered by FUDForum. Page generated in 0.02932 seconds
