Home » Modeling » Amalgam » Default update sites
Default update sites [message #525233] Fri, 26 March 2010 06:37 Go to next message
Gregoire Dupe is currently offline Gregoire Dupe
Member
The default updates sites of the package
eclipse-modeling-helios-M6-incubation-win32.zip are:
* file:/home/data/httpd/download.eclipse.org/eclipse/updates/3 .6milestones/
* http://download.eclipse.org/mpc/repo
* http://download.eclipse.org/technology/epp/packages/helios
file:/shared/technology/epp/epp_repo/helios/epp.build/buildr esult/org.eclipse.epp.allpackages.helios.feature_1.3.0-eclip se.feature/site.p2/
* file:/home/data/httpd/download.eclipse.org/releases/staging/
Is it normal that "file:/" updates site are unable by default?
Is it normal that the http://download.eclipse.org/releases/helios/ is
not enabled by default?
Grégoire Dupé
Re: Default update sites [message #525235 is a reply to message #525233] Fri, 02 April 2010 03:50 Go to previous messageGo to next message
Cedric Brun is currently offline Cedric Brun
Nop, it's not normal and it deserves a bug in EPP, Mariot has been quicker
than you :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=302070
Cédric
Gregoire Dupe wrote:
> * http://download.eclipse.org/mpc/repo *
> http://download.eclipse.org/technology/epp/packages/helios *
eclipse.feature/site.p2/
> Grégoire Dupé
Re: Default update sites [message #525236 is a reply to message #525235] Fri, 02 April 2010 10:51 Go to previous message
Member
Thank you for your answer.
The bug 302070 doesn't tell any things about the fact that the update
site http://download.eclipse.org/releases/helios/ is not enabled by default.
I think this is a problem because when somebody tries to install a tool
from a project update site, he get errors explaining that some plug-ins
cannot be found. And he does not know where to find the required plug-ins.
One example of such problem, can be found in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306992
Grégoire
Re: Default update sites [message #587340 is a reply to message #525233] Fri, 02 April 2010 03:50 Go to previous message
than you :
Cédric
> Grégoire Dupé
Re: Default update sites [message #587351 is a reply to message #525235] Fri, 02 April 2010 10:51 Go to previous message
Member
Grégoire
Previous Topic:Default update sites
Next Topic:Eclipse Modeling Components Discovery feedback
Current Time: Tue May 28 08:07:18 EDT 2013
Powered by FUDForum. Page generated in 0.01546 seconds
