| DSL toolkit book - problem when running tranformations [message #525228] |
Thu, 31 December 2009 11:26  |
Martin Baez Messages: 12 Registered: July 2009 |
Junior Member |
I am developing a dsl toolkit and trying to give support for running
some atl, qvto and xpand tranformations programatically.
I am a bit lost when trying to understand how invokations must be done
and found some problems when running the transformations:
1) The m2t tranformation(TransformMindmap2Csv class) was not running
beacuse the code is commented, I uncommented the code and used the
org.eclipse.emf.mwe plugins in order to compile the uncommented code,
but when I try to export a mindmap diagram to cvs nothing happens, after
some debug I found this issue reported for the WorkflowRunner
[ERROR]: Class not found: 'org.eclipse.xpand2.Generator'
What bundle am I missing?, I understood that the dsl sample must be used
with the ganymede version, but what version of xpand should I use?
2) I cannot run the transformations(mindmap to requirementes for
example) because the wizard reported this error:
"Cannot find imported module
'/org.eclipse.amalgam.examples.dnc.TransformDnc2Java.transfo rmationId' "
Any clue?, by the way the book is great!!
thanks in advance
colo
| Re: DSL toolkit book - problem when running tranformations [message #525229 is a reply to message #525228] |
Sun, 10 January 2010 20:57  |
Junior Member |
Anybody has a clue about the problem I have with the sample code? , I
try to describe them better:
1_ When I run the "Export to cvs" tranformation I get this error:
EvaluationException : No Definition 'mindmap2csv::Main for mindmap::Map'
found!
[23,67] on line 1 'EXPAND mindmap2csv::Main FOR
model.typeSelect(mindmap::Map).first()'
2_ When I try to run the "transform to requirements" transformation I
get this one:
What am I missing?. am I the only one with these problems? :(
thanks
colo
> thanks in advance
> colo
| Re: DSL toolkit book - problem when running tranformations [message #587257 is a reply to message #525228] |
Junior Member |
found!
get this one:
thanks
colo
> thanks in advance
> colo
FUDForum. Page generated in 0.01755 seconds
