Home » Eclipse Projects » Equinox » Unable to satisfy dependency
Unable to satisfy dependency [message #524814] Fri, 02 April 2010 12:24
Philip Borlin is currently offline Philip Borlin
Member
I had my application building with 3.5.1. It built the bundles and created a p2 repository and everything was great. When I updated to 3.6M5 I started getting these errors:
[java] [p2.mirror] Unable to satisfy dependency from myfeature.feature.group 1.0.0.201004020943 to org.eclipse.equinox.p2.engine [1.0.100,2.0.0).
[java] [p2.mirror] Unable to satisfy dependency from myfeature.feature.group 1.0.0.201004020943 to org.eclipse.equinox.p2.metadata [1.0.0,2.0.0).
[java] [p2.mirror] Unable to satisfy dependency from myfeature.feature.group 1.0.0.201004020943 to org.eclipse.equinox.p2.core [1.0.100,2.0.0).
Which later on down the build fails the build by causing these problems:
[java] runDirector:
[java] [p2.director] Installing myproduct 1.0.0.201004020943.
[java] [p2.director] Installation failed.
[java] [p2.director] Cannot complete the install because one or more required items could not be found.
[java] [p2.director] Software being installed: Product 1.0.0.201004020943 (myproduct 1.0.0.201004020943)
[java] [p2.director] Missing requirement: Product Client 1.0.0.201004020943 (myFeature.feature.group 1.0.0.201004020943) requires 'org.eclipse.equinox.p2.engine [1.0.100,2.0.0)' but it could not be found
[java] [p2.director] Cannot satisfy dependency:
[java] [p2.director] From: Product 1.0.0.201004020943 (myproduct 1.0.0.201004020943)
[java] [p2.director] To: myFeature.feature.group [1.0.0.201004020943]
[java] A problem occured while invoking the director.
The three bundles above are all in the same directory the other eclipse bundles are and they are found during the compile part of the build since the compile is not failing. Any ideas where I should be looking to solve this problem? More information is available if needed.
Previous Topic:Start equinox using jar
Next Topic:java.lang.ClassCircularityError: de/kue/msgbus/channel/IChannelService
Current Time: Sat May 18 07:36:07 EDT 2013
Powered by FUDForum. Page generated in 0.01576 seconds
