Home » Newcomers » Newcomers » Highlight all matches for various text(general text highlighting feature)
Highlight all matches for various text [message #524579] Thu, 01 April 2010 09:51 Go to next message
Maxim Veksler is currently offline Maxim Veksler
How can I enable an arbitrary text highlighting in Eclipse IDE?
To explain what I mean go to
1. Help > Help Contents
2. Hit ctrl+f
3. Make sure "Highlight all matches" is checked
4. enter the text "he"
You will notice that all text occurrence contains "he" will be highlighted.
I want the same functionality for the main Editor window.
I'm not speaking about "Search" highlighting because that is a vary long and contains many user clicks way to do such a simple and IMHO very common task.
p.s. I'm not sure if this plugin http://colorer.sourceforge.net/eclipsecolorer/ could provide the described feature.
Thanks for the help,
Maxim.
Re: Highlight all matches for various text [message #524679 is a reply to message #524579] Thu, 01 April 2010 14:38 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
Try enabling "Mark Occurrences" (Control-Alt-O or from the toolbar) and then
use the incremental search: Control-J and then start typing. This highlights
all occurrences in my testing.
Brian.
Re: Highlight all matches for various text [message #525762 is a reply to message #524679] Wed, 07 April 2010 13:22 Go to previous messageGo to next message
Brian de Alwis wrote on Thu, 01 April 2010 14:38
Brian.
Hi Brian,
It did not work for me. Ctrl + J indeed does increment search but only the first result gets highlighted.
I'm looking for something like Chrome (Chromium) search which is IMHO perfect implementation for quick text search.
Any ideas?
Re: Highlight all matches for various text [message #526667 is a reply to message #524579] Mon, 12 April 2010 10:34 Go to previous messageGo to next message
Georgi Apostolov is currently offline Georgi Apostolov
I have problem with highlight too. I want to see where start and end my bracelets
Like this: http://i73.photobucket.com/albums/i211/xspy/eclipse-bracers. jpg
I searched all day, no results Sad
Re: Highlight all matches for various text [message #526668 is a reply to message #526667] Mon, 12 April 2010 10:40 Go to previous messageGo to next message
Georgi Apostolov wrote on Mon, 12 April 2010 10:34
Indeed notepad++ highlighting is marvelous. It has the feature I am after (highlight all occurrences of the word on mouse double click) plus the mentioned above feature and a plethora of other very much helpful text editor tweaks.
Eclipse should adopt this editor highlighting logic into it's own editor. It would make many people happy.
Perhaps this deserves a feature request in Bugzilla ?
Re: Highlight all matches for various text [message #528483 is a reply to message #526668] Tue, 20 April 2010 12:30 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
>> my bracelets
>> Like this:
>> http://i73.photobucket.com/albums/i211/xspy/eclipse-bracers jpg
>> I searched all day, no results :(
> text editor tweaks.
Eclipse already does this for other programming languages; if that
feature is not available in the PHP editor, I do suggest you check
Bugzilla; there is most likely a feature request for it already. Keep in
mind that this is open source and just having a request for a feature
does not magically make it appear in the next release; materializing
features takes contribution from the community.
Eric
Re: Highlight all matches for various text [message #549583 is a reply to message #524579] Tue, 27 July 2010 05:34 Go to previous messageGo to next message
No real name is currently offline No real name
Ctrl + shift + a finds 'occurances in a file' that highlights all occurances of the selected text as you describe.
Through the GUI its on the 'source' menu.
Re: Highlight all matches for various text [message #549736 is a reply to message #549583] Tue, 27 July 2010 14:57 Go to previous messageGo to next message
What version of eclipse are you using? I don't see such option in 3.6 EE version (Java Perspective).
Re: Highlight all matches for various text [message #630905 is a reply to message #524579] Tue, 05 October 2010 10:39 Go to previous messageGo to next message
I have found this plugin for text highlighting
http://code.google.com/p/eclipse-glance/
It works like Notepad++ on doubleclick word highlighting after pressing Ctrl+Alt+F in any (!) Eclipse editor
Re: Highlight all matches for various text [message #631372 is a reply to message #630905] Thu, 07 October 2010 06:30 Go to previous message
No Real Name wrote on Tue, 05 October 2010 10:39
THANK YOU.
If this was stackoverflow here you would get an up vote + selected answer + A thank you very much comment Smile from me.
[Updated on: Thu, 07 October 2010 06:30]
Report message to a moderator
Previous Topic:Can't start eclipse
Next Topic:Editor window.
Current Time: Sun May 26 03:11:20 EDT 2013
Powered by FUDForum. Page generated in 0.01975 seconds
