Home » Modeling » UML2 Tools » Adding operations to Class Diagram (Adding operations to Class Diagram )
Adding operations to Class Diagram [message #524001] Tue, 30 March 2010 05:06 Go to next message
savutu  is currently offline savutu
I am trying to add operations to a class diagram. I am able to add simple operation like add(), but how can I set In parameters and return type of this operation,please suggest
thanks,
Re: Adding operations to Class Diagram [message #524493 is a reply to message #524001] Thu, 01 April 2010 03:42 Go to previous messageGo to next message
Eclipse User
context menu (click right) -> manage parameters
properties sheet -> Type
GreetX,
Thorsten
Re: Adding operations to Class Diagram [message #546917 is a reply to message #524493] Wed, 14 July 2010 11:32 Go to previous messageGo to next message
Tonté  Pouncil is currently offline Tonté Pouncil
I am having the same problem when it comes to specifying type that are not primatives. For example, I would like to greate an operation like so: +getSearchResults():List<SomeObject> or +getSearchResults():<Generalization Set> SomeObject>.
Any suggestion would be greatly appreciated.
Thanks!
Re: Adding operations to Class Diagram [message #549130 is a reply to message #546917] Sat, 24 July 2010 19:58 Go to previous message
Andres  is currently offline Andres
Member
For example for the operation +getSearchResults():List<>
1-click left on your class, and clik operation icon
2-In properties sheet set the name as getSearchResults
3-You can set the return type, in properties sheet -> Type.
To set List, you should have a Class named List, in your diagram(current resource package when you click in type properties), or in a other ecore file(load resources).
4-To set the parameters
Click left in your opeation class(in the diagram), and edit directly the name and types of parameters.For example, if your operation is op1(param1:String), write param1:String.
If you now go to context menu (click right) -> manage parameters, you can see your new parameter and type,(i can`t directly edit de type of a parameter in manage parameter)
I hope this help you.
Previous Topic:Unexpected layout of elements inside Component
Next Topic:Adding operations to Class Diagram
Current Time: Sat May 25 13:54:03 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
