| RPT - Error connecting to citrix servers [message #523446] |
Fri, 26 March 2010 09:56  |
No real name Messages: 1 Registered: March 2010 |
Junior Member |
Hello all,
Im getting stuck with Rational Performance Tester.
I try to create the Citrx recording through HTTP recording on Citrix Web Interface 4.6.0.18291.
I get the usual message regarding the Certificate, and after installing it I launch the application I need to test.
At this point is when the error is raised complaining about the Certificate was offered by Hyades but connection was done to xxxx.yyyy.zzz
Recording is not complete so i cant use it for creating the Citrx recording.
I also tryed using the .ica file provided by the web interface but no connection to citrix happens.
The main problem here is that the Citrix environments are maintained by the Client.
Can anyone give any advice please??
Another cuestion. Can the RPT be used to test .exe apps installed in my desktop PC.
I mean, if i install the Clarify CRM application in local, can i test it with RPT?
Thank you so much!!!
Regards.
| Re: RPT - Error connecting to citrix servers [message #523785 is a reply to message #523446] |
Mon, 29 March 2010 06:15  |
Paul Slauenwhite Messages: 970 Registered: July 2009 |
Sorry, you have posted to the wrong news group. Please post your questions
to a RPT news group.
Paul
<ridick13@gmail.com> wrote in message news:hoieeb$cfa$1@build.eclipse.org...
> Hello all,
> recording.
> the Client.
> desktop PC. I mean, if i install the Clarify CRM application in local, can
> i test it with RPT?
> Regards.
FUDForum. Page generated in 0.02001 seconds
