| ATF installation/building problems on MacOSX [message #523435] |
Fri, 26 March 2010 09:42  |
Jan F. Messages: 7 Registered: March 2010 |
Junior Member |
I am trying to get ATF working on MacOSX but am encountering problems along everything I try.
Here is what I am doing:
Mac OS X Snow Leopard
Eclipse 3.5 Galileo SR2, PDE, 64 bit cocoa version, downloaded from here: http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/galileo/SR2/eclipse-rcp-galileo-SR2 -macosx-cocoa-x86_64.tar.gz
1, the installation path (following http://wiki.eclipse.org/ATF/Installing)
- unzip the Eclipse, choose workspace
- follow the steps in the ATF/Installation page exactly
On trying to run using Run As -> Run in Mozilla, it switches to the Web Browser Tools perspective, but subsequently fails with an error:
Unhandled event loop exception
No more handles [Could not detect registered XULRunner to use]
I looked into the XULRunner plugin, but the JAR seems to be empty.
I tried to download XULRunner separately and install it, but that did not help.
2. the building ATF part (following http://wiki.eclipse.org/ATF/Workspace)
- follow the steps in ATF/Workspace page exactly
Checked out the team set, went to releng and clicked Set as Target Platform in the atf.target file.
This download whole bunch of stuff as expected, but along the way shows this error:
An internal error occurred during: "Resolving Target Definition".
Profile TARGET_DEFINITION:resource:/org.eclipse.atf.releng/pde/atf.t arget is not current.
Ultimately finishes, but an error is still shown in org.eclipse.atf.debug.test:
Bundle 'org.eclipse.wst.common.project.facet.ui' cannot be resolved MANIFEST.MF /org.eclipse.atf.debug.test/META-INF line 12 Plug-in Problem
The project was not built since its build path is incomplete. Cannot find the class file for org.eclipse.core.runtime.CoreException. Fix the build path then try building this project org.eclipse.atf.debug.test Unknown Java Problem
The type org.eclipse.core.runtime.CoreException cannot be resolved. It is indirectly referenced from required .class files ATFProjectHelper.java /org.eclipse.atf.debug.test/src/org/eclipse/atf/debug/testpl ugin line 1 Java Problem
If I try to run the ATF core configuration, I get:
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Can anybody shed a light on how to get ATF working (ideally through the ATW/Workspace path)?
-Jan
| Re: ATF installation/building problems on MacOSX [message #523498 is a reply to message #523435] |
Fri, 26 March 2010 11:25   |
Jacek Pospychala Messages: 159 Registered: July 2009 |
hi Jan,
the problem may be related to the x86_64 platform. If you followed wiki
install steps, you probably installed Mozilla XULRunner from Zend update
site. Unfortunately it's missing 64-bit build for Mac, because Mozilla
provides only 32bit builds.
So you have two alternative options:
1. find x86_64 XULRunner build for Mac and launch Eclipse with extra
params -vmargs
-Dorg.eclipse.swt.browser.XULRunnerPath=/path/to/64bitXulrun ner
2. get Eclipse 32bit build and try standard install there again
Thanks for trying ATF!
Jacek
> here:
> not help.
> shows this error:
> Plug-in Problem
> line 1 Java Problem
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> -Jan
| Re: ATF installation/building problems on MacOSX [message #523745 is a reply to message #523518] |
Mon, 29 March 2010 03:12  |
Jan F. wrote:
> Hi Jacek,
> thanks for a quick reply!
> Yes, switching to 32-bit version of Galileo fixed the installation
> troubles. I will update the wiki page to note that the steps do not
> work for 64-bit version.
> I am still getting the same errors trying to build ATF from sources
> though. I can provide the error log, if it is going to be useful in
> any way.
> -Jan
Jan,
thanks for updating the wiki.
You could get ATF on Eclipse 64-bit to work by building Mozilla from the
sources. I tried it for Linux 64-bit, so if you're interested, I can
provide some hints.
Looking at the activity in this bug:
https://bugzilla.mozilla.org/show_bug.cgi?id=512489 it's very Linux
64-bit builds will be finally officially supported soon by Mozilla.
Here's also bug related to supporting Mac 64 bit:
https://bugzilla.mozilla.org/show_bug.cgi?id=519060
So 64-bit platforms may officially get some more love soon :-)
Jacek
| Re: ATF installation/building problems on MacOSX [message #562982 is a reply to message #523498] |
Fri, 26 March 2010 12:46  |
Junior Member |
Hi Jacek,
Yes, switching to 32-bit version of Galileo fixed the installation troubles. I will update the wiki page to note that the steps do not work for 64-bit version.
I am still getting the same errors trying to build ATF from sources though. I can provide the error log, if it is going to be useful in any way.
-Jan
| Re: ATF installation/building problems on MacOSX [message #562998 is a reply to message #562982] |
Jan F. wrote:
> Hi Jacek,
> any way.
> -Jan
Jan,
provide some hints.
Jacek
FUDForum. Page generated in 0.01648 seconds
