| Issue with EclipseLink and Felix OSGi [message #523624] |
Sat, 27 March 2010 10:04  |
No real name Messages: 3 Registered: March 2010 |
Junior Member |
I'm new to Felix OSGi, and have tried this simple example: http://wiki.eclipse.org/EclipseLink/Examples/OSGi/Developing _with_EclipseLink_OSGi_in_PDE. In Equinox everything works great if I follow the steps in the tutorial. However, I want to set it up in a Felix framework.
I have followed http://felix.apache.org/site/integrating-felix-with-eclipse. html to get Felix within Eclipse. This also works, and the basic examples for this work aswell. However, when I try to get EclipseLink working in Felix I get an exception:
org.osgi.framework.BundleException: Activator start error in bundle hello.jpa [15].
at org.apache.felix.framework.Felix.activateBundle(Felix.java:1 803)
at org.apache.felix.framework.Felix.startBundle(Felix.java:1678 )
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java: 905)
at org.apache.felix.shell.impl.StartCommandImpl.execute(StartCo mmandImpl.java:114)
at org.apache.felix.shell.impl.Activator$ShellServiceImpl.execu teCommand(Activator.java:286)
at org.apache.felix.shell.tui.Activator$ShellTuiRunnable.run(Ac tivator.java:184)
at java.lang.Thread.run(Unknown Source)
Caused by: Exception [EclipseLink-30005] (Eclipse Persistence Services - 1.1.3.v20091002-r5404): org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption
Exception Description: An exception was thrown while searching for persistence archives with ClassLoader: org.eclipse.persistence.internal.jpa.deployment.osgi.Composi teClassLoader @1bbf1ca
Internal Exception: java.lang.IllegalStateException: The bundle is uninstalled.
at org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption.exceptionSearchingForPersistenceResources(Persistence UnitLoadingException.java:121)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:133)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:67)
at javax.persistence.Persistence.createEntityManagerFactory(Unk nown Source)
at hello.jpa.Activator.start(Activator.java:14)
at org.apache.felix.framework.util.SecureAction.startActivator( SecureAction.java:661)
at org.apache.felix.framework.Felix.activateBundle(Felix.java:1 756)
... 6 more
Caused by: java.lang.IllegalStateException: The bundle is uninstalled.
at org.apache.felix.framework.Felix.getBundleResources(Felix.ja va:1407)
at org.apache.felix.framework.BundleImpl.getResources(BundleImp l.java:618)
at org.eclipse.persistence.internal.jpa.deployment.osgi.BundleP roxyClassLoader.findResources(BundleProxyClassLoader.java:43 )
at java.lang.ClassLoader.getResources(Unknown Source)
at org.eclipse.persistence.internal.jpa.deployment.osgi.Composi teClassLoader.getResources(CompositeClassLoader.java:118)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntity ManagerFactory(PersistenceProvider.java:96)
... 12 more
-> Exception [EclipseLink-30005] (Eclipse Persistence Services - 1.1.3.v20091002-r5404): org.eclipse.persistence.exceptions.PersistenceUnitLoadingExc eption
The installed bundles within Felix are:
START LEVEL 1
ID State Level Name
[ 0] [Active ] [ 0] System Bundle (2.0.4)
[ 1] [Active ] [ 1] Apache Felix Bundle Repository (1.4.3)
[ 2] [Active ] [ 1] Apache Felix Shell Service (1.4.2)
[ 3] [Active ] [ 1] Apache Felix Shell TUI (1.4.1)
[ 4] [Active ] [ 1] JPA 1.0 - Extended for OSGi (1.99) (1.99.0.v200906021518)
[ 5] [Active ] [ 1] Apache Derby Plug-in (10.1.2.1_v200803061811)
[ 9] [Active ] [ 1] EclipseLink JPA (1.1.3.v20091002-r5404)
[ 10] [Active ] [ 1] EclipseLink Core (1.1.3.v20091002-r5404)
[ 12] [Active ] [ 1] JAXP XML (1.3.4.v200902170245)
The plugin dependencies of the test-tutorial are: javax.persistence_1.99, org.apache.derby, org.eclipse.osgi, javax.transaction.
I've been looking into this for days. And I can't figure out how to get this simple example working. I have tried to make it work with Pax Runner aswell, but no success.
If anyone can help me, it would be very much appreciated.
Thanks in advance.
Aerv
EDIT: basically, if anyone knows how to make http://wiki.eclipse.org/EclipseLink/Examples/OSGi/Developing _with_EclipseLink_OSGi_in_PDE this work in Felix OSGi, in Eclipse, like which plug-in dependencies am I missing, or which bundles do I have to install in Felix... That would be really helpful!
[Updated on: Sat, 27 March 2010 10:08] Report message to a moderator
| Re: Issue with EclipseLink and Felix OSGi [message #523805 is a reply to message #523624] |
Mon, 29 March 2010 08:45   |
Shaun Smith Messages: 189 Registered: July 2009 |
Hi Aerv,
You're missing some bundles in your deployment to Felix. You need
the ones listed in the screenshot in the "Running your Application"
section of the example
( http://wiki.eclipse.org/EclipseLink/Examples/OSGi/Developing _with_EclipseLink_OSGi_in_PDE#Running_your_Application).
Add the EclipseLink ANTLR and ASM bundles.
The example shows the set of bundles deployed to Equinox:
id State Bundle
0 ACTIVE org.eclipse.osgi_3.5.0.v20090520
1 ACTIVE hello.jpa_1.0.0.qualifier
2 ACTIVE org.eclipse.persistence.antlr_1.1.2.v20090526-r4309
3 ACTIVE org.eclipse.persistence.asm_1.1.2.v20090526-r4309
4 ACTIVE org.eclipse.persistence.core_1.1.2.v20090526-r4309
5 ACTIVE org.eclipse.persistence.jpa_1.1.2.v20090526-r4309
6 ACTIVE org.apache.derby.core_10.3.1.4
7 ACTIVE javax.persistence_1.99.0
--Shaun
On 27/3/2010 10:04 AM, woutervanisterdael@gmail.com wrote:
> Hello,
> I have followed
> get an exception:
> hello.jpa [15].
> mmandImpl.java:114)
> tivator.java:184)
> mailto: org.eclipse.persistence.internal.jpa.deployment.osgi.Composi teClassLoader @1bbf1ca
> uninstalled.
> Source)
> Source)
> ... 6 more
> ... 12 more
> uninstalled.
> START LEVEL 1
> ID State Level Name
> javax.transaction.
> Thanks in advance.
> Aerv
Oracle <http://www.oracle.com>
Shaun Smith | Principal Product Manager
Phone: +19055023094
Oracle Server Technologies, Oracle TopLink
ORACLE Canada | 110 Matheson Boulevard West, Suite 100, Mississauga,
Ontario | L5R 3P4
Green Oracle <http://www.oracle.com/commitment> Oracle is committed to
developing practices and products that help protect the environment
FUDForum. Page generated in 0.01648 seconds
