| Using p2 model to generate a p2 site [message #521750] |
Thu, 18 March 2010 12:33  |
Henrik Lindberg Messages: 2426 Registered: July 2009 |
I am about to start implementing p2 publishing support in b3 engine.
My approach is to use the p2 ecore model in the aggregator, and hoping
that there is code there that I can just call.
Two questions...
- The p2 model is nested at the moment. Should we break it out into its
own bundle?
- Once I have populated a p2 model, how to I write it out as a "p2 repo
on disk" ?
- henrik
| Re: Using p2 model to generate a p2 site [message #603469 is a reply to message #522900] |
Wed, 24 March 2010 14:34  |
On 3/24/10 1:47 PM, Filip Hrbek wrote:
> Sorry for late answer. Comments inside. I can help with implementing
> the changes if you like.
> Filip
> Henrik Lindberg wrote:
>> Two questions...
>> own bundle?
> Yes, I think that it would be nice to share one common p2 model for
> everything in b3.
I logged this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306979
>> on disk" ?
> Currently we can only read a p2 repository into the model. We have
> "importToModel" methods which scan the original p2 structure and copy it
> into the EMF model. Perhaps we need to write inverse methods to push the
> model into a native p2 repository instance to be able to store it.
....and this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=306980
- henrik
FUDForum. Page generated in 0.01617 seconds
