| Re: Need help on using EMF Compare feature [message #521626] |
Thu, 18 March 2010 06:42  |
Ed Merks Messages: 24553 Registered: July 2009 |
Viswanath,
It's best to ask about EMF Compare on the EMFT newsgroup/forum starting
with [EMF Compare] in the subject line; I've added it to the "to" list
of the reply.
I don't believe there's any support for graphically visualizing the
model differences.
viswanath wrote:
> Hi I am new user to Eclipse,
> With the help of the documentation online about the EMF compare
> plugin, I was able to compare two state charts.
> But the diff is text based, How can I get the diff in model based, or
> is there any provision to convert the diff text into model by some
> means .. Need Urgent help.
> Thanks in advance.
> Viswanath B
> Embedded developer in Automotive OEM.
| Re: Need help on using EMF Compare feature [message #523037 is a reply to message #522354] |
Wed, 24 March 2010 16:16  |
Marcelo Messages: 14 Registered: February 2010 |
Junior Member |
Hi, Viswanath,
Have you tried to save your diff model in .emfdiff format?
Try this:
final ComparisonResourceSnapshot snapshot =
DiffFactory.eINSTANCE.createComparisonResourceSnapshot();
snapshot.setDate(Calendar.getInstance().getTime());
snapshot.setMatch(matchModel); // your match model generated by the
comparison
snapshot.setDiff(diffModel); // your diff model generated by the comparison
ModelUtils.save(snapshot, "result.emfdiff");
I am supposing you are using the recent releases of EMF Compare. Older
releases have the same logic, but different class names.
Open the result.emfdiff file and tell us if this is what you needed. It
should be open in "Compare" view.
All the best,
Marcelo Schots
Em 22/03/2010 10:24, Laurent Goubet escreveu:
> Thanks for the forwarding Ed :).
> Viswanath, The diff you obtain through EMF Compare is actually a model,
> and it is serialized as an xmi file. How do you use EMF Compare and how
> did you obtain a "text based" diff?
> Laurent Goubet
> Obeo
> Ed Merks wrote:
>> Viswanath,
>> starting with [EMF Compare] in the subject line; I've added it to the
>> "to" list of the reply.
>> model differences.
>>> Thanks in advance. Viswanath B
| Re: Need help on using EMF Compare feature [message #622363 is a reply to message #521626] |
Mon, 22 March 2010 09:24  |
Laurent Goubet Messages: 1548 Registered: July 2009 |
--------------010508080405040801050505
Content-Type: text/plain; charset=UTF-8; format=flowed
Laurent Goubet
Obeo
Ed Merks wrote:
> Viswanath,
> of the reply.
> model differences.
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010508080405040801050505--
| Re: Need help on using EMF Compare feature [message #622394 is a reply to message #522354] |
Junior Member |
Hi, Viswanath,
Try this:
comparison
All the best,
Marcelo Schots
> Laurent Goubet
> Obeo
> Ed Merks wrote:
>> Viswanath,
>> model differences.
FUDForum. Page generated in 0.01812 seconds
