| [Fwd: [jwt-dev] Re: newbie with editor problems] [message #521332] |
Wed, 17 March 2010 05:48 |
Marc Dutoo Messages: 71 Registered: July 2009 |
Member |
--------------070208090409030308050406
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Stephanie
FYI - Your problem reminds Chris of something, please open a bug as said
Marc
Content-Type: message/rfc822;
name="[jwt-dev] Re: newbie with editor problems.eml"
Content-Disposition: inline;
filename="[jwt-dev] Re: newbie with editor problems.eml"
Return-Path: <jwt-dev-bounces@eclipse.org>
Delivered-To: marc.dutoo@openwide.fr
Received: from mail.corp.accelance.fr (mail.corp.accelance.fr [213.162.48.15])
by mail.corp.accelance.fr (lmtpd) with LMTP id 26749.002;
Tue, 16 Mar 2010 22:06:25 +0100 (CET)
X-policyd-weight: using cached result; rate: -7.7
Received-SPF: none (mail.corp.accelance.fr: 206.191.52.55 is neither permitted nor denied by domain of eclipse.org) client-ip=206.191.52.55; envelope-from=jwt-dev-bounces@eclipse.org; helo=mail.eclipse.org;
Received: from mail.eclipse.org (node5.eclipse.org [206.191.52.55])
by mail.corp.accelance.fr (Postfix) with SMTP id 9C4497E888;
Tue, 16 Mar 2010 22:06:24 +0100 (CET)
Received: from node5.eclipse.org (localhost [127.0.0.1])
by mail.eclipse.org (Postfix) with ESMTP id 5FAED86E95;
Tue, 16 Mar 2010 17:24:20 -0400 (EDT)
X-Original-To: jwt-dev@eclipse.org
Delivered-To: jwt-dev@eclipse.org
by mail.eclipse.org (Postfix) with SMTP id DB22686E64
for <jwt-dev@eclipse.org>; Tue, 16 Mar 2010 17:24:12 -0400 (EDT)
Received: from [192.168.2.197] (corp-gw.accelance.net [213.162.48.17])
by mail.corp.accelance.fr (Postfix) with ESMTP id 7BBEC7E888;
Tue, 16 Mar 2010 22:05:54 +0100 (CET)
Message-ID: <4B9FF6FB.3060704@openwide.fr>
Date: Tue, 16 Mar 2010 22:24:11 +0100
User-Agent: Thunderbird 2.0.0.21 (X11/20090318)
MIME-Version: 1.0
Newsgroups: eclipse.technology.jwt
To: Stephanie.Smith@sas.com
References: <hn3ubk$fao$1@build.eclipse.org>
In-Reply-To: <hn3ubk$fao$1@build.eclipse.org>
Cc: Java Workflow Toolbox <jwt-dev@eclipse.org>
Subject: [jwt-dev] Re: newbie with editor problems
X-BeenThere: jwt-dev@eclipse.org
X-Mailman-Version: 2.1.5
Precedence: list
Reply-To: Java Workflow Toolbox <jwt-dev@eclipse.org>
List-Id: Java Workflow Toolbox <jwt-dev.eclipse.org>
List-Unsubscribe: <https://dev.eclipse.org/mailman/listinfo/jwt-dev>,
<mailto:jwt-dev-request@eclipse.org?subject=unsubscribe>
List-Archive: <https://dev.eclipse.org/mailman/private/jwt-dev>
List-Post: <mailto:jwt-dev@eclipse.org>
List-Help: <mailto:jwt-dev-request@eclipse.org?subject=help>
List-Subscribe: <https://dev.eclipse.org/mailman/listinfo/jwt-dev>,
<mailto:jwt-dev-request@eclipse.org?subject=subscribe>
Sender: jwt-dev-bounces@eclipse.org
Errors-To: jwt-dev-bounces@eclipse.org
Hi Stephanie
First of all, a warm welcome to the JWT community.
Your problem is indeed very weird. Please confirm that you've download=20
it using the "install new software..." menu item from within Eclipse 3.5 =
Then I'll ask you to file a bug at=20
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=3DJWT and mention you=
r=20
exact execution environment (Java & OS version etc.) as required there.=20
We'll try to reproduce and patch it, at least that'll be something to=20
talk about when the development team will meet at EclipseCon next week !
If you have further questions, I advise you to rather ask them on the=20
mailing list, that core developers are more likely to monitor and be=20
ready to answer questions on : jwt-dev@eclipse.org .
Marc
Stephanie.Smith@sas.com a =C3=A9crit :
> I downloaded 0.7.0 and am trying to work thru the example shown in the=20
> tutorial. It all starts out fine. I can create the action, the=20
> connection points and the new Role. But once i create the Role and add=20
> it tothe diagram, i can't do anything else. I cannot add a new action,=20
> draw any connections etc.
>=20
> I was using the pallette to select the item i wanted to create and then=
=20
> clicked in the diagram area. This all worked fine up to the point where=
=20
> the role was created and added to the diagram.
>=20
> Any ideas on what i am doing wrong? Once i get to this behavior, I=20
> cannot do anything. Even if i create a new model.
_______________________________________________
jwt-dev mailing list
jwt-dev@eclipse.org
--------------070208090409030308050406--
FUDForum. Page generated in 0.02977 seconds
