| Unsupported Driver.getClientInfo() operation when Eclipselink 2.0.0 accesses TimesTen 11.2.1 [message #520687] |
Sun, 14 March 2010 07:40  |
Max WF Poon Messages: 16 Registered: July 2009 |
Junior Member |
According to http://wiki.eclipse.org/Using_EclipseLink_JPA_Extensions_(ELUG), TimesTen is supported with EclipseLink 2.0. However, I tried to configure EclipseLinki 2.0 to access TimesTen 11.2.1 (on Glassfish v3, Sun JDK6u17 and WindowsXP) with the following persistence.xml :-
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="memoryDB_AppPU" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider >
<jta-data-source>jdbc/TimesTenXADB</jta-data-source>
<class>persistenceApp.entities.ManufacturerInMemory</class >
<class>persistenceApp.entities.ProductInMemory</class>
<class>persistenceApp.entities.ProductCodeInMemory</class>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.target-database" value="TimesTen"/>
<property name="eclipselink.target-server" value="SunAS9"/>
<property name="eclipselink.logging.level" value="ALL"/>
</properties>
</persistence-unit>
</persistence>
Glassfish v3 configurations for TimesTen DataSources (both not working for above) include:
Non-XA
- DataSource: jdbc/TimeTenDB
- JNDI Name: TimesTenPool
- Resource Type: javax.sql.ConnectionPoolDataSource
- Resource ClassName: com.timesten.jdbc.ObservableConnectionDS
XA
- DataSource: jdbc/TimeTenXADB
- JNDI Name: TimesTenXAPool
- Resource Type: javax.sql.XADataSource
- Resource ClassName: com.timesten.jdbc.xa.TimesTenXADataSource
But got the following exception during EclipseLink JPA access to TimesTen (other earlier JDBC access to TimesTen were successfully executed) which seems to show that there are operations that may not be supported with TimesTen (but tested to be ok with other IMDB such as Apache Derby).
Are these configurations ok at least on EclipseLink part? Did I miss anything? Any advice? Thanks.
Glasfish server log as follows
INFO: EclipseLink, version: Eclipse Persistence Services - 2.0.0.v20091127-r5931
WARNING: RAR7114: Unable to get ClientInfo for connection
java.sql.SQLException: Driver does not support this function
at com.timesten.jdbc.JdbcOdbcConnection.getClientInfo(JdbcOdbcC onnection.java:2526)
at com.timesten.jdbc.ProxyConnection.getClientInfo(ProxyConnect ion.java:744)
at com.sun.gjc.spi.jdbc40.ConnectionHolder40.getClientInfo(Conn ectionHolder40.java:362)
at com.sun.gjc.spi.jdbc40.ConnectionHolder40.init(ConnectionHol der40.java:90)
at com.sun.gjc.spi.jdbc40.ConnectionHolder40.<init>(ConnectionHolder40.java:81)
at com.sun.gjc.spi.jdbc40.ConnectionWrapper40.<init>(ConnectionWrapper40.java:60)
at com.sun.gjc.spi.jdbc40.Jdbc40ObjectsFactory.getConnection(Jd bc40ObjectsFactory.java:86)
at com.sun.gjc.spi.ManagedConnection.getConnection(ManagedConne ction.java:397)
at com.sun.enterprise.resource.allocator.ConnectorAllocator.fil lInResourceObjects(ConnectorAllocator.java:168)
at com.sun.enterprise.resource.pool.ConnectionPool.getResource( ConnectionPool.java:423)
at com.sun.enterprise.resource.pool.PoolManagerImpl.getResource FromPool(PoolManagerImpl.java:227)
at com.sun.enterprise.resource.pool.PoolManagerImpl.getResource (PoolManagerImpl.java:151)
at com.sun.enterprise.connectors.ConnectionManagerImpl.getResou rce(ConnectionManagerImpl.java:315)
at com.sun.enterprise.connectors.ConnectionManagerImpl.internal GetConnection(ConnectionManagerImpl.java:280)
at com.sun.enterprise.connectors.ConnectionManagerImpl.allocate Connection(ConnectionManagerImpl.java:172)
at com.sun.enterprise.connectors.ConnectionManagerImpl.allocate Connection(ConnectionManagerImpl.java:149)
at com.sun.enterprise.connectors.ConnectionManagerImpl.allocate Connection(ConnectionManagerImpl.java:144)
at com.sun.gjc.spi.base.DataSource.getConnection(DataSource.jav a:105)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIC onnector.java:126)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIC onnector.java:94)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDa tasource(DatasourceLogin.java:162)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.connectInternal(DatasourceAccessor.java:327)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.connectInternal(DatabaseAccessor.java:294)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.connect(DatasourceAccessor.java:415)
at org.eclipse.persistence.sessions.server.ConnectionPool.build Connection(ConnectionPool.java:155)
at org.eclipse.persistence.sessions.server.ExternalConnectionPo ol.startUp(ExternalConnectionPool.java:118)
at org.eclipse.persistence.sessions.server.ServerSession.connec t(ServerSession.java:495)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImp l.login(DatabaseSessionImpl.java:632)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryPro vider.login(EntityManagerFactoryProvider.java:230)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:368)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:151)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:207)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:195)
at org.glassfish.persistence.jpa.PersistenceUnitLoader.doJava2D B(PersistenceUnitLoader.java:273)
at org.glassfish.persistence.jpa.JPADeployer.load(JPADeployer.j ava:155)
at org.glassfish.persistence.jpa.JPADeployer.load(JPADeployer.j ava:55)
at org.glassfish.internal.data.ModuleInfo.load(ModuleInfo.java: 175)
at org.glassfish.internal.data.ApplicationInfo.load(Application Info.java:216)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(App licationLifecycle.java:338)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(App licationLifecycle.java:183)
at org.glassfish.deployment.admin.DeployCommand.execute(DeployC ommand.java:272)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$1.execute(Comm andRunnerImpl.java:305)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(Comm andRunnerImpl.java:320)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(Comm andRunnerImpl.java:1176)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$900(Com mandRunnerImpl.java:83)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionConte xt.execute(CommandRunnerImpl.java:1235)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionConte xt.execute(CommandRunnerImpl.java:1224)
at com.sun.enterprise.v3.admin.AdminAdapter.doCommand(AdminAdap ter.java:365)
at com.sun.enterprise.v3.admin.AdminAdapter.service(AdminAdapte r.java:204)
at com.sun.grizzly.tcp.http11.GrizzlyAdapter.service(GrizzlyAda pter.java:166)
at com.sun.enterprise.v3.server.HK2Dispatcher.dispath(HK2Dispat cher.java:100)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service( ContainerMapper.java:245)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTa sk.java:791)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.j ava:693)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.jav a:954)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultPr otocolFilter.java:170)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(D efaultProtocolChain.java:135)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocol Chain.java:102)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocol Chain.java:88)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolC hain.java:76)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChai nContextTask.java:53)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyCon textTask.java:57)
at com.sun.grizzly.ContextTask.run(ContextTask.java:69)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(Abstra ctThreadPool.java:330)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractT hreadPool.java:309)
at java.lang.Thread.run(Thread.java:619)
WARNING: RAR7115: Unable to set ClientInfo for connection
java.sql.SQLClientInfoException: Driver does not support this function
at com.timesten.jdbc.JdbcOdbcConnection.setClientInfo(JdbcOdbcC onnection.java:2549)
at com.timesten.jdbc.ProxyConnection.setClientInfo(ProxyConnect ion.java:772)
at com.sun.gjc.spi.jdbc40.ConnectionHolder40.setClientInfo(Conn ectionHolder40.java:313)
at com.sun.gjc.spi.jdbc40.ConnectionHolder40.close(ConnectionHo lder40.java:519)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.closeDatasourceConnection(DatabaseAccessor.java:467)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.closeConnection(DatasourceAccessor.java:498)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.closeConnection(DatabaseAccessor.java:490)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.decrementCallCount(DatasourceAccessor.java:271)
at org.eclipse.persistence.internal.databaseaccess.DatasourceAc cessor.connect(DatasourceAccessor.java:427)
[Updated on: Sun, 14 March 2010 09:04] Report message to a moderator
FUDForum. Page generated in 0.01604 seconds
